Component: API UART Dummy (API Slave Devices)
| Version | 2.0 |
API UART Dummy component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_API_UART_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_UART_Dummy.fcfx
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-53 | |
| State | |
| Range: 0-1 | |
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
| UARTReceive | |
| Channel | |
| UARTSend | |
| Channel | |
| Data | |
| Properties |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-53 | |
| State | |
| Range: 0-1 | |
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
| UARTReceive | |
| Channel | |
| UARTSend | |
| Channel | |
| Data | |
| Properties |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-53 | |
| State | |
| Range: 0-1 | |
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
| UARTReceive | |
| Channel | |
| UARTSend | |
| Channel | |
| Data | |
| Properties |
| UARTCheckRX | |
| Channel | |
| UARTInitialise | |
| Channel | |
| IOSetOutputPin | |
| Pin | |
| Range: 0-53 | |
| State | |
| Range: 0-1 | |
| IOGetInputPin | |
| Pin | |
| Range: 0-19 | |
| UARTReceive | |
| Channel | |
| UARTSend | |
| Channel | |
| Data | |
| Properties |
