| Author
Matrix TSL
| Version
1.0
| Category
Wireless
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_ESP32_SPP.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_ESP32_SPP.fcfx
A simple example file showing how to send and receive data using the ESP32 Bluetooth Serial Port Profile.
ESP_BT
The SPP legacy bluetooth mode must be enabled in the ESP32 config file to allow SSP to work. For details please see this forum topic.
For problems sending strings or missing data bytes, please see this forum topic.
ReceiveByte
| Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured
- UINT
Timeout
| Number of ms to wait for incoming data
- UINT
SendString
| Sends a string to the Bluetooth serial connection
- STRING
Data
| Data Array to send
ReceiveINTArray
| Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT
Data
| Array to store the incoming data
- BYTE
NumValues
| Maximum number of values to try and receive
- BOOL
MSBfirst
| 0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- BYTE
SendINTArray
| Transmits an array of 16-bit INT/UINT values via the Bluetooth peripheral
- UINT
Data
| Data Array to send
- BYTE
NumValues
| Number of 16-bit values to send from the array
- BOOL
MSBfirst
CheckConnectionStatus
| Checks to see if the Bluetooth device is connected. Returns 1 if connected.
- BOOL
ReceiveCount
| Collects the number of bytes currently stored in the receive buffer.
- UINT
ReceiveArray
| Attempts to receive an array of bytes from the bluetooth serial port. Returns the number of bytes received.
- BYTE
Data
| Buffer to place received data into
- UINT
MaxBytes
| Max number of bytes to try and read within the time
- UINT
Timeout
- UINT
SendArray
| Sends a byte to the Bluetooth serial connection
- BYTE
Data
| Data Array to send
- UINT
NumBytes
| Number of bytes to send
SendByte
- BYTE
Data
ReceiveString
- UINT
MaxBytes
- UINT
Timeout
- STRING
| Starts up the Bluetooth communications SPP service.
Device Name
| Sets the Bluetooth device friendly name
Receive Buffer
| Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
Data Receive Interrupt
Verbose Debug
| When enabled debug messages will be placed onto UART CH1 which is generally connected to via a Serial to USB IC to pipe messages back to the host PC.
COM Port
| Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
| When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
| Baud rate passed to the COM port to control the rate of data.
ReceiveByte
- UINT
Timeout
- UINT
SendString
- STRING
Data
| Data Array to send
ReceiveINTArray
- UINT
Data
- BYTE
NumValues
- BOOL
MSBfirst
- BYTE
Timeout
- BYTE
SendINTArray
- UINT
Data
| Data Array to send
- BYTE
NumValues
- BOOL
MSBfirst
- BOOL
ReceiveCount
- UINT
ReceiveArray
- BYTE
Data
- UINT
MaxBytes
- UINT
Timeout
- UINT
SendArray
- BYTE
Data
| Data Array to send
- UINT
NumBytes
SendByte
- BYTE
Data
ReceiveString
- UINT
MaxBytes
- UINT
Timeout
- STRING
Device Name
Receive Buffer
Verbose Debug
COM Port
Refresh COM Ports
Baud
ReceiveByte
- UINT
Timeout
- UINT
SendString
- STRING
Data
| Data Array to send
ReceiveINTArray
- UINT
Data
- BYTE
NumValues
- BOOL
MSBfirst
- BYTE
Timeout
- BYTE
SendINTArray
- UINT
Data
| Data Array to send
- BYTE
NumValues
- BOOL
MSBfirst
- BOOL
ReceiveCount
- UINT
ReceiveArray
- BYTE
Data
- UINT
MaxBytes
- UINT
Timeout
- UINT
SendArray
- BYTE
Data
| Data Array to send
- UINT
NumBytes
SendByte
- BYTE
Data
ReceiveString
- UINT
MaxBytes
- UINT
Timeout
- STRING
Device Name
Receive Buffer
Verbose Debug
COM Port
Refresh COM Ports
Baud
ReceiveByte
- UINT
Timeout
- UINT
SendString
- STRING
Data
| Data Array to send
ReceiveINTArray
- UINT
Data
- BYTE
NumValues
- BOOL
MSBfirst
- BYTE
Timeout
- BYTE
SendINTArray
- UINT
Data
| Data Array to send
- BYTE
NumValues
- BOOL
MSBfirst
- BOOL
ReceiveCount
- UINT
ReceiveArray
- BYTE
Data
- UINT
MaxBytes
- UINT
Timeout
- UINT
SendArray
- BYTE
Data
| Data Array to send
- UINT
NumBytes
SendByte
- BYTE
Data
ReceiveString
- UINT
MaxBytes
- UINT
Timeout
- STRING
Device Name
Receive Buffer
Verbose Debug
COM Port
Refresh COM Ports
Baud
