Component: COM Port (Runtime Tools)
Revision as of 09:52, 27 January 2023 by Wiki bot (talk | contribs)
Version 3.0
Category Runtime Tools
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
FC6 Icon.png Auto Detect Example
Fc9-comp-macro.png ReceiveByte
Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property.
Fc9-u16-icon.png - UINT Timeout
Time to wait for incoming data in milliseconds
Fc9-comp-macro.png ConfigureConsole
Fc9-u8-icon.png - BYTE Status
Fc9-comp-macro.png SendString
Sends an string of characters to the COM port.
Data byte array to send
Fc9-comp-macro.png ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
Fc9-u16-icon.png - UINT Data
Array to store the incoming data
Fc9-u8-icon.png - BYTE NumValues
Maximum number of values to try and receive
Fc9-bool-icon.png - BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
Fc9-u8-icon.png - BYTE Timeout
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
Max time in ms to wait in between bytes
Fc9-bool-icon.png - BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
Fc9-comp-macro.png SendBinary16Bit
Sends out a 16-bit binary value split across two bytes.
Fc9-u16-icon.png - UINT Value
Fc9-comp-macro.png SendINTArray
Transmits an array of 16-bit INT/UINT values via the UART peripheral
Data to transmit
Number of 16-bit values to send from the array
Fc9-comp-macro.png SendNumber
Sends out a number as an ASCII String from the UART interface.
Fc9-s32-icon.png - LONG Number
Fc9-comp-macro.png ReceiveBinary32Bit
Receives a binary 32-bit value split across four bytes.
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png ClosePort
Closes the currently open COM port, ending communications and allowing it to be accessed via another application.
Fc9-comp-macro.png ReceiveBinaryFloat
Receives a binary 32-bit floating point value split across four bytes.
Fc9-comp-macro.png SendByte
Sends a single byte to be sent out via the COM port.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png SetDTRState
Allows the DTR signal to be enabled or disabled.
Fc9-u8-icon.png - BYTE State
A value of 0 disables the DTR, 1 or above willl enable the DTR.
Fc9-comp-macro.png ScanForDeviceID
Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
Fc9-string-icon.png - STRING HWID
Example: "VID_12BF&PID_0101"
Fc9-comp-macro.png SendByteArray
Sends an array of bytes to the COM port.
Number of bytes to send
Fc9-comp-macro.png ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
Fc9-comp-macro.png ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
Fc9-comp-macro.png SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
Fc9-f32-icon.png - FLOAT Number
Fc9-comp-macro.png SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
Fc9-u32-icon.png - ULONG Number
Fc9-u8-icon.png - BYTE NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
Fc9-bool-icon.png - BOOL Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
Fc9-comp-macro.png SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
A value of 0 disables flow control, 1 or above willl enable flow control.
Fc9-comp-macro.png OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
Fc9-comp-macro.png ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
Look for prefix before receiving, 1=0xFF, 0=FF
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
Fc9-u32-icon.png - ULONG Value
Fc9-comp-macro.png SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-comp-macro.png ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
Fc9-u16-icon.png - UINT MaxLength
Max number of bytes to try and read
Fc9-comp-macro.png ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Fc9-type-14-icon.png Baud
Baud rate passed to the COM port to control the rate of data.
Fc9-type-14-icon.png Timeout Value
Value to specify what is returned when no incoming receive data is present.
Fc9-type-7-icon.png Auto Close
Auto close the port on Sim stop event
Fc9-type-16-icon.png New Line Format
Data to transmit
Data to transmit
Data to transmit
