| Author
Matrix TSL
| Version
1.1
| Category
E-blocks 1
Touch Pads component
This board provides five touch areas for use with capacitive sensing. Hence five digital touch switches can be implemented. This component directly interfaces with the EB088 CapTouch E-block.
Please click here to download the component source project: FC_Comp_Source_CapTouchEB088.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CapTouchEB088.fcfx
GetTouchValue
| Samples the touch sensor ADC value and returns it Always samples both channels, but only returns the chosen channel
- BYTE
Switch
| 0=Up, 1=Right, 2=Down, 3=Left, 4=Center
- UINT
GetTouchPressed
| Returns non-zero if touch detected
- BYTE
Switch
- UINT
OffValue
- BYTE
Threshold
| Provide the threshold value for the pad to be considered touched
- BOOL
Up Channel
| ADC Channel number
Right Channel
Down Channel
Left Channel
Center Channel
Simulation Properties
Up Switch
On Value
Off Value
Right Switch
On Value
Off Value
Down Switch
On Value
Off Value
Left Switch
On Value
Off Value
Center Switch
On Value
Off Value
GetTouchValue
- BYTE
Switch
- UINT
GetTouchPressed
- BYTE
Switch
- UINT
OffValue
- BYTE
Threshold
- BOOL
Up Channel
| ADC Channel number
Right Channel
Down Channel
Left Channel
Center Channel
Up Switch
On Value
Off Value
Right Switch
On Value
Off Value
Down Switch
On Value
Off Value
Left Switch
On Value
Off Value
Center Switch
On Value
Off Value
GetTouchValue
- BYTE
Switch
- UINT
GetTouchPressed
- BYTE
Switch
- UINT
OffValue
- BYTE
Threshold
- BOOL
Up Channel
| ADC Channel number
Right Channel
Down Channel
Left Channel
Center Channel
Up Switch
On Value
Off Value
Right Switch
On Value
Off Value
Down Switch
On Value
Off Value
Left Switch
On Value
Off Value
Center Switch
On Value
Off Value
GetTouchValue
- BYTE
Switch
- UINT
GetTouchPressed
- BYTE
Switch
- UINT
OffValue
- BYTE
Threshold
- BOOL
Up Channel
| ADC Channel number
Right Channel
Down Channel
Left Channel
Center Channel
Up Switch
On Value
Off Value
Right Switch
On Value
Off Value
Down Switch
On Value
Off Value
Left Switch
On Value
Off Value
Center Switch
On Value
Off Value
