Component: Output Digital (DSP Outputs)
Revision as of 15:20, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Outputs
Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
Please click here to download the component source project: FC_Comp_Source_DSP_Output.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Output.fcfx
GetIntArray
Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- UINT Data
- UINT Count
GetLongArray
Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- ULONG Data
- UINT Count
GetFloatArray
Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- FLOAT Data
- UINT Count
GetFloat
Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- FLOAT Return
GetLong
Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- ULONG Return
GetInt
Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
GetByteArray
Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
- BYTE Data
- UINT Count
GetByte
Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Connect To
Auto Scale
Automatically scale the buffer type to the output type Yes: Provide automatic scaling No: Transfer data as is, maybe truncated
GetIntArray
- UINT Data
- UINT Count
GetLongArray
- ULONG Data
- UINT Count
GetFloatArray
- FLOAT Data
- UINT Count
GetFloat
- FLOAT Return
GetLong
- ULONG Return
GetInt
GetByteArray
- BYTE Data
- UINT Count
GetByte
Connect To
Auto Scale
GetIntArray
- UINT Data
- UINT Count
GetLongArray
- ULONG Data
- UINT Count
GetFloatArray
- FLOAT Data
- UINT Count
GetFloat
- FLOAT Return
GetLong
- ULONG Return
GetInt
GetByteArray
- BYTE Data
- UINT Count
GetByte
Connect To
Auto Scale
