| Author
Matrix TSL
| Version
2.0
| Category
API Slave Devices
API (ESP32) component
Connects to an ESP32 device running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ESP32_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ESP32_API_Comp.fcfx
The App Developer (ESP32) component allows an ESP32 board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ESP32 hardware the board must first be pre-programmed with dedicated firmware.
The firmware source project can be downloaded from here.
You will need to set your WIFI SSID and Password near the top of Main to allow the ESP module to connect to your network.
ESP32 App Developer Firmware
The IP Address to the ESP32 hardware is selected via the SCADA_ESP32 component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the address for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
Please note pins 34, 35, 36, 39 are only capable of digital inputs and cannot be used as digital outputs.
| App Developer Slave Digital Pin
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
21
22
23
25
26
27
32
33
34
35
36
39
| Device Port Pin
A0
A1
A2
A3
A4
A5
A6
A7
A8
A9
A10
A11
A12
A13
A14
A15
A16
A17
A18
A19
A21
A22
A23
A25
A26
A27
B0
B1
B2
B3
B4
B7
| GPIO Number
0
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
21
22
23
25
26
27
32
33
34
35
36
39
Please note not all analogue input pins are available as peripheral ADC2 is not accesible when WIFI/Bluetooth is active. Only the pins shown are available.
| App Developer Slave Analogue Pin
0
3
4
5
6
7
| Device Port Pin
B4
B7
B0
B1
B2
B3
| GPIO Number
36
39
32
33
34
35
Please note that PWM channels are tied in pairs and so channel 0 and 1 use the same internal timer peripheral. They will always run at the same frequency and when enabling channel 1 channel 0 duty will be reset to 0% and visa versa.
| App Developer Slave Peripheral Pin
I2C 0 SDA
I2C 0 SCL
I2C 1 SDA
I2C 1 SCL
SPI 0 MOSI
SPI 0 MISO
SPI 0 SCK
SPI 1 MOSI
SPI 1 MISO
SPI 1 SCK
UART 0 RX
UART 0 TX
UART 1 RX
UART 1 TX
PWM 0
PWM 1
PWM 2
PWM 3
PWM 4
PWM 5
PWM 6
PWM 7
PWM 8
PWM 9
PWM 10
PWM 11
OneWire
| Device Port Pin
A13
A12
A15
A14
A9
A10
A11
A6
A7
A8
A26
A25
B0
B1
A0
A2
A4
A5
A12
A13
A14
A15
A16
A17
A18
A19
A21
| GPIO Number
13
12
15
14
9
10
11
6
7
8
26
25
32
33
0
2
4
5
12
13
14
15
16
17
18
19
21
PortA = GPIO pins 0 - 31 : A0 = GPIO 0
PortB = GPIO pins 32 - 39 : B0 = GPIO 32
I2CInitialise
| Initialise the I2C module ready for communications
- BYTE
| Channel Index: Range 0 - I2C Bus Count - 1
- BYTE
Baud
| 0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
| Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
| Delay in us between each sample
- BYTE
Samples
| 8-bit samples returned from the function
SPITransferTrans
| Transfer an array of bytes using the SPI bus
- BYTE
| Channel Index: Range 0 - SPI Bus Count - 1
- UINT
Count
| Number of bytes to send and receive
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
OneWireBusReset
| Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BYTE
- BOOL
IOGetInputPin
| Sets the selected digital pin to an input and reads the input state.
- BYTE
Pin
| Range: 0-29
- BOOL
UARTBaud
| Control the communications rate of the UART module
- BYTE
| Channel Index: Range 0 - UART Bus Count - 1
- BYTE
Rate
| 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200
OneWireInitialise
| Initialise the OneWire module ready for communications
- BYTE
OneWireMatchROM
| Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE
- BYTE
FamilyCode
- BYTE
SerialNumber
ADCSample8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
I2CTransReceive
| Receives an I2C Transaction on the selected I2C channel. Returns the number of bytes received.
- BYTE
- BYTE
Data
| Data variable to receive into
- UINT
Count
| Number of bytes to receive
- UINT
UARTInitialise
| Initialise the UART module ready for communications
- BYTE
UARTCheckRX
| Check to see if the UART module has received any data
- BYTE
- BYTE
ADCSetPrechargeTime
| Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
- BYTE
ChargeTime
| Default 10
OneWireTransmitByte
| Transmit a byte to the one wire bus a bit at a time
- BYTE
- BYTE
Data
I2CRestart
| Put the I2C Module into Restart mode
- BYTE
PWMDisable
| Disable a PWM output
- BYTE
| Range: 0-11
I2CStart
| Put the I2C Module into Start mode
- BYTE
SPITransfer
| Transfer a byte using the SPI bus
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
| Receive a byte using the I2C bus
- BYTE
- BOOL
Last
| Last byte to receive: Range 0-1
- BYTE
OneWireGetIDByte
| Returns a single byte of the 64-Bit lasered ROM code, 255 on error
- BYTE
- BYTE
Device
| Device ID - Range: 0 - NumDevices - 1
- BYTE
ByteIndex
| Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
- BYTE
PWMSetFrequency
| Sets PWM frequency in Hz
- BYTE
| Range: 0 - 11
- LONG
Frequency
| Frequency (Hz)
I2CStop
| Put the I2C Module into Stop mode
- BYTE
ADCSetReferenceVoltage
| Specified the reference setting for ADC reads.
- BYTE
RefType
| 0=AREF, 1=VCC, 3=Internal 1.1V
OneWireSkipROM
| Performs a bus reset and the sends the SkipROM command byte
- BYTE
SPIPrescaler
| Modify the speed of the SPI bus
- BYTE
- BYTE
Prescaler
| Range: 0-2
PWMSetDuty
| Sets the duty for the PWM output
- BYTE
| Range: 0-11
- BYTE
Duty
ADCSample10
| Reads the voltage present on an Analog pin as an 12-bit value range 0-4095
- BYTE
ADCChannel
| Range: 0, 3-7
- UINT
I2CTransSend
| Sends an I2C Transaction on the selected I2C channel. Returns the number of bytes sent.
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
| Number of bytes to send out, MS bit 0x8000 signifies no Stop if set
- UINT
I2CTransInit
| Initialises the I2C Transaction mode with the 7-bit device address
- BYTE
- BYTE
DeviceAddress
| 7-bit Device Address
- BYTE
Baud
IOSetOutputPin
| Sets the selected digital pin to an output and assigns the output state.
- BYTE
Pin
| Range: 0-29
- BOOL
State
| Range: 0-1
UARTReceive
| Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available.
- BYTE
- BYTE
ADCSampleAverage10
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023. Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
OneWireScanBus
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE
- BYTE
SPIInitialise
| Initialsie the SPI module ready for communications
- BYTE
OneWireReceiveByte
| Receives a byte from the one wire bus a bit at a time
- BYTE
- BYTE
I2CSend
| Transmit a byte using the I2C bus
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
| Send a byte via the UART module
- BYTE
- BYTE
Data
| Data Byte to send. Range: 0-255
OneWireGetDeviceCount
| Returns the number of devices found by the last ScanBus operation.
- BYTE
- BYTE
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-11
ADCSampleArray10
| Reads the voltage present on an Analog pin as an 10-bit value range 0-1023 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
| 10-bit samples returned from the function
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
| Initialise the comms to the Arduino board ready for commands to be sent.
Connection
ESP IP Address
| IP Address of the Raspbery Pi we want to control
ESP Port
| Port number we want to communicate on. Default 1234
Network Interface
| Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
IP Address
| IP Address of the selected network interface.
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
OneWire
SERVO
Console
Console Log
| Create an automatic console log of the commands sent to the ESP
Log Mode
| Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
I2CInitialise
- BYTE
- BYTE
Baud
ADCSampleArray8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
OneWireBusReset
- BYTE
- BOOL
IOGetInputPin
- BYTE
Pin
| Range: 0-29
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
OneWireInitialise
- BYTE
OneWireMatchROM
- BYTE
- BYTE
FamilyCode
- BYTE
SerialNumber
ADCSample8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
- UINT
Count
- UINT
UARTInitialise
- BYTE
UARTCheckRX
- BYTE
- BYTE
ADCSetPrechargeTime
- BYTE
ChargeTime
| Default 10
OneWireTransmitByte
- BYTE
- BYTE
Data
I2CRestart
- BYTE
PWMDisable
- BYTE
| Range: 0-11
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
OneWireGetIDByte
- BYTE
- BYTE
Device
- BYTE
ByteIndex
- BYTE
PWMSetFrequency
- BYTE
| Range: 0 - 11
- LONG
Frequency
| Frequency (Hz)
I2CStop
- BYTE
- BYTE
RefType
OneWireSkipROM
- BYTE
SPIPrescaler
- BYTE
- BYTE
Prescaler
| Range: 0-2
PWMSetDuty
- BYTE
| Range: 0-11
- BYTE
Duty
ADCSample10
- BYTE
ADCChannel
| Range: 0, 3-7
- UINT
I2CTransSend
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
- BYTE
Baud
IOSetOutputPin
- BYTE
Pin
| Range: 0-29
- BOOL
State
| Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
OneWireScanBus
- BYTE
- BYTE
SPIInitialise
- BYTE
OneWireReceiveByte
- BYTE
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
- BYTE
- BYTE
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-11
ADCSampleArray10
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
ESP IP Address
ESP Port
Network Interface
IP Address
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
OneWire
SERVO
Console
Console Log
Log Mode
I2CInitialise
- BYTE
- BYTE
Baud
ADCSampleArray8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- BYTE
Samples
SPITransferTrans
- BYTE
- UINT
Count
- BYTE
DataOut
| Outgoing data
- BYTE
DataIn
| Incoming data
OneWireBusReset
- BYTE
- BOOL
IOGetInputPin
- BYTE
Pin
| Range: 0-29
- BOOL
UARTBaud
- BYTE
- BYTE
Rate
OneWireInitialise
- BYTE
OneWireMatchROM
- BYTE
- BYTE
FamilyCode
- BYTE
SerialNumber
ADCSample8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
I2CTransReceive
- BYTE
- BYTE
Data
- UINT
Count
- UINT
UARTInitialise
- BYTE
UARTCheckRX
- BYTE
- BYTE
ADCSetPrechargeTime
- BYTE
ChargeTime
| Default 10
OneWireTransmitByte
- BYTE
- BYTE
Data
I2CRestart
- BYTE
PWMDisable
- BYTE
| Range: 0-11
I2CStart
- BYTE
SPITransfer
- BYTE
- BYTE
DataOut
- BYTE
I2CReceive
- BYTE
- BOOL
Last
- BYTE
OneWireGetIDByte
- BYTE
- BYTE
Device
- BYTE
ByteIndex
- BYTE
PWMSetFrequency
- BYTE
| Range: 0 - 11
- LONG
Frequency
| Frequency (Hz)
I2CStop
- BYTE
- BYTE
RefType
OneWireSkipROM
- BYTE
SPIPrescaler
- BYTE
- BYTE
Prescaler
| Range: 0-2
PWMSetDuty
- BYTE
| Range: 0-11
- BYTE
Duty
ADCSample10
- BYTE
ADCChannel
| Range: 0, 3-7
- UINT
I2CTransSend
- BYTE
- BYTE
Data
| Data to send
- UINT
Count
- UINT
I2CTransInit
- BYTE
- BYTE
DeviceAddress
- BYTE
Baud
IOSetOutputPin
- BYTE
Pin
| Range: 0-29
- BOOL
State
| Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- UINT
OneWireScanBus
- BYTE
- BYTE
SPIInitialise
- BYTE
OneWireReceiveByte
- BYTE
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
- BOOL
UARTSend
- BYTE
- BYTE
Data
- BYTE
- BYTE
PWMEnable
| Enable a PWM output
- BYTE
| Range: 0-11
ADCSampleArray10
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
- BYTE
ADCChannel
| Range: 0, 3-7
- BYTE
SampleCount
| Range: 1- 100
- BYTE
SampleDelay
- BYTE
Connection
ESP IP Address
ESP Port
Network Interface
IP Address
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
OneWire
SERVO
Console
Console Log
Log Mode
