Component: Flash EEPROM (EEPROM)
Revision as of 15:21, 20 January 2023 by Wiki bot (talk | contribs)
Category EEPROM
Flash EEPROM component
Provides an emulated version of EEPROM using the microcontrollers on-board flash program memory. Requires a microcontroller with write and erase access to the flash memory.
Please click here to download the component source project: FC_Comp_Source_FlashEE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FlashEE.fcfx
Fc9-comp-macro.png Read
Reads a single value from the Flash EEPROM at the specified address
Fc9-u16-icon.png - UINT Address
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png Write
Writes a single value to the Flash EEPROM at the specified address
Fc9-u32-icon.png - ULONG Data
Fc9-type-7-icon.png Enabled
Is the Flash EEPROM component currently supported on the selected MCU device?
Fc9-type-16-icon.png Number Of Values
Number of individual values that can be read and written using the component. The more values you want the bigger the RAM buffer required to store the data when performing a write.
Fc9-type-16-icon.png Flash Page
Flash Page to use as EEPROM
Fc9-type-21-icon.png Flash Address
Fc9-type-10-icon.png Initialiser
Fc9-type-21-icon.png Bits Per Value
Number of bits available when initialising the Flash memory.
Fc9-type-21-icon.png Bits Per Instruction
Number of bits that can be stored or retreived using a single flash address
