| Author
Matrix Ltd.
| Version
2.0
| Category
Wireless
GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
Please click here to download the component source project: FC_Comp_Source_GSM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GSM.fcfx
DialNumber
| Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response.
- STRING
Number
- BYTE
GetTextString
| Collects the text message data from an incoming text message.
- BYTE
NumBytes
- STRING
SendString
| Sends a string to the GSM module.
- STRING
Text
SendScript
| Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE
idx
- BYTE
SendCommand
| Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply
- STRING
Command
- BYTE
SendCR
- BYTE
AnswerIncomingCall
| Answers the phone for an incoming type call. Returns 0 for success and 255 for failure.
- BYTE
GetTextNumber
| Collects the sender's phone number from an incoming text message.
- BYTE
NumBytes
- STRING
HangUpCall
| Ends a voice based call. Returns 0 for success and 255 for failure.
- BYTE
ReadString
| Copies the data from the data string array to a local string variable
- BYTE
NumBytes
- STRING
SendTextMessage
| Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure.
- STRING
Number
- STRING
Message
- BYTE
StringReceive
| Attempts to receive a string from the GSM modem.
- BYTE
DeleteAllMessages
| Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail.
- BYTE
CheckNetworkStatus
| Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
- BYTE
CheckForIncoming
| Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
- BYTE
| Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
- BYTE
Expect Echo
| Sets if we expect an echo of any data we send out to the GSM modem. Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
String Array Size
| Amount of RAM memory to dedicate to receiving responces from the GSM
Message Array Size
| Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
Script Count
| Maximum number of scripts to store in the device's ROM
Script1
| ASCII based AT command data stored in ROM and used when sending script 1
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
Use Flow Control
| Flow Control (Handshake) enable or disable. On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
Baud Options
| Baud rate option selector
| Textual label shown on the component I/O flasher
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data API component on the Panel.
DialNumber
- STRING
Number
- BYTE
GetTextString
- BYTE
NumBytes
- STRING
SendString
- STRING
Text
SendScript
- BYTE
idx
- BYTE
SendCommand
- STRING
Command
- BYTE
SendCR
- BYTE
AnswerIncomingCall
- BYTE
GetTextNumber
- BYTE
NumBytes
- STRING
HangUpCall
- BYTE
ReadString
- BYTE
NumBytes
- STRING
SendTextMessage
- STRING
Number
- STRING
Message
- BYTE
StringReceive
- BYTE
DeleteAllMessages
- BYTE
CheckNetworkStatus
- BYTE
CheckForIncoming
- BYTE
- BYTE
Expect Echo
String Array Size
Message Array Size
Script Count
Script1
TX
RX
Use Flow Control
Baud Options
Console Columns
Data Source
DialNumber
- STRING
Number
- BYTE
GetTextString
- BYTE
NumBytes
- STRING
SendString
- STRING
Text
SendScript
- BYTE
idx
- BYTE
SendCommand
- STRING
Command
- BYTE
SendCR
- BYTE
AnswerIncomingCall
- BYTE
GetTextNumber
- BYTE
NumBytes
- STRING
HangUpCall
- BYTE
ReadString
- BYTE
NumBytes
- STRING
SendTextMessage
- STRING
Number
- STRING
Message
- BYTE
StringReceive
- BYTE
DeleteAllMessages
- BYTE
CheckNetworkStatus
- BYTE
CheckForIncoming
- BYTE
- BYTE
Expect Echo
String Array Size
Message Array Size
Script Count
Script1
TX
RX
Use Flow Control
Baud Options
Console Columns
Data Source
