Component: GameCode (Misc Circuit)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Author Jef De Bruyne
Category Misc Circuit
GameCode component
A small handheld device designed for creating embedded games. Complete with a 8 x 16 LED display, 4-Way DPAD with 4 additional push switches Buzzer, Vibration, MP3 Player, Potentiometer and Lithium battery management. Programmed via USB.
Please click here to download the component source project: FC_Comp_Source_GameCode_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GameCode_Master.fcfx
GSM Example Example should show the following on the display on the panel and on the hardware.
The AT injector component allows us to simulate the response of the GSM module.
PlayNote
Output a single note on the buzzer. Specify the desired frequency (Hz) and duration (ms).
- UINT Frequency
Sets the pitch for the note in Hz. Range 1-20000 Hz
- ULONG Duration
Time period to play the note for in milliseconds. Range 0-65535 ms
DisplayWrite
Write an array containing 16 bytes to the display to illuminate the corresponding dots. The index represents the line (Y-axis), starting from 0 for the uppermost line. The value of the byte represents the column (X-axis), with MSB the leftmost dot.
- BYTE Array
Index = line, Content (byte) = column
PotRead
Read and return the value of the potentiometer. If desired, give the upper limit to scale the output value. Enter "MaxValue = 0" to skip scaling and get the byte value (0-255)
- UINT MaxValue
Scale the return value. Enter 0 to skip.
PwrLedSet
Control the PWR LED. 0 = red + green 1 = red 2 = green
- BYTE Value
0 = red + green, 1 = red, 2 = green
EEStoreValue
Saves a value to none volitile memory
- BYTE Address
Address to write to, Range: 0-255
- BYTE Value
Value to store, Range: 0-255
MP3PlayTrack
Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. "0001-anyname.mp3". Other folder track numbers should be 3 characters long e.g. "001-anyname.mp3".
- BYTE Directory
0=Root, 01=Folder "01" - 99=Folder "99", 100=Folder "MP3", 101=Advert
- UINT Track
Track number 1 = "001.mp3" / "0001.mp3"
MP3GetStatus
Returns the status of the MP3 module. 0 = module in sleep 1 = track is playing 2 = track is pauzed 3 = track is stopped
MP3PausePlayResetStop
Allows the current playing track to be paused, restarted or stopped.
- BYTE Mode
0=Pause, 1=Play, 2=Reset, 3=Stop
MP3SendCommand
Send commands to MP3 module. Check datasheet for info.
- BYTE Command
- BYTE Para1
- BYTE Para2
EEReadValue
Retreives a value from none volitile memory
- BYTE Address
DisplayWriteNumber
Show a number ranging from 000 to 999 on the display. Number is printed vertically.
- UINT Value
Enter a number from 0 to 999.
DisplayClear
Clear the display.
BatteryRead
Read and return the voltage level of the battery in millivolt.
LedsWrite
Set the button-leds. MSB = leftmost led LSB = rightmost led
- BYTE Value
MSB = leftmost dot, LSB = rightmost dot
MP3SetVolume
Sets the volume level for the MP3 module
- BYTE Volume
Range: 0 (min) - 30 (max)
DisplayBrightness
Control the brightness of the display.
- BYTE Value
Enter value from 0 to 15
Initializes all present hardware and communication. Place this at the very start of your code.
LED Colours
LED On
LED Off
Display Colours
On Colour
Off Colour
Background Colour
PlayNote
- UINT Frequency
- ULONG Duration
DisplayWrite
- BYTE Array
PotRead
- UINT MaxValue
PwrLedSet
- BYTE Value
EEStoreValue
- BYTE Address
- BYTE Value
MP3PlayTrack
- BYTE Directory
- UINT Track
MP3GetStatus
- BYTE Mode
MP3SendCommand
- BYTE Command
- BYTE Para1
- BYTE Para2
EEReadValue
- BYTE Address
DisplayWriteNumber
- UINT Value
DisplayClear
Clear the display.
BatteryRead
LedsWrite
- BYTE Value
MP3SetVolume
- BYTE Volume
DisplayBrightness
- BYTE Value
LED Colours
LED On
LED Off
Display Colours
On Colour
Off Colour
Background Colour
PlayNote
- UINT Frequency
- ULONG Duration
DisplayWrite
- BYTE Array
PotRead
- UINT MaxValue
PwrLedSet
- BYTE Value
EEStoreValue
- BYTE Address
- BYTE Value
MP3PlayTrack
- BYTE Directory
- UINT Track
MP3GetStatus
- BYTE Mode
MP3SendCommand
- BYTE Command
- BYTE Para1
- BYTE Para2
EEReadValue
- BYTE Address
DisplayWriteNumber
- UINT Value
DisplayClear
Clear the display.
BatteryRead
LedsWrite
- BYTE Value
MP3SetVolume
- BYTE Volume
DisplayBrightness
- BYTE Value
LED Colours
LED On
LED Off
Display Colours
On Colour
Off Colour
Background Colour
