Component: Hall Effect Digital (Magnetic)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Magnetic
Hall Effect Digital component
Simple digital hall effect on off switch triggered by the proximity of another object.
Please click here to download the component source project: FC_Comp_Source_HallEffect_Digital.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_HallEffect_Digital.fcfx
Sample program using the EBM011 - Hall Effect sensor
Reads the sensor and displays output on LED D7. FC6 Icon.png EBM011 Example
Fc9-comp-macro.png ReadState
Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state.
Fc9-comp-macro.png SetTarget
Set the object that you want to test for collision with. If this is not called, or is called with handle = 0, collisions will be tested against every panel object that has 'Solid' status. NB) Specifying an object will save CPU power!!
Fc9-h32-icon.png - HANDLE Target
The object to test for collision with.
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the detector goes high. 'Polarity' will affect whether high value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Fc9-comp-macro.png WaitUntilLow
Pause the program until the detector goes low. 'Polarity' will affect whether low value represents a collision or separation. NB) In simulation, only use this macro if testing for collision with animated or timer driven objects!!
Fc9-type-5-icon.png Pin
The chip pin that will receive the switch status.
Fc9-type-16-icon.png Polarity
Select the pin state that will indicate that an object has been detected.
Fc9-conn-icon.png Simulation
Fc9-type-17-icon.png Magnet Object
Select an object from the panel to act as the magnet that triggers the reed switch.
Fc9-type-15-icon.png Range
Distance within which the switch is activated. NB) This is measured between the centre of the proximity switch and the centre of the target object.
Fc9-type-21-icon.png Timer Interval (ms)
Time in milliseconds between testing for proximity. Small time = Greater CPU load Large time = More like to miss activation if it is very brief.
