Component: LCD (Grove - UART) (Alphanumeric)
Revision as of 15:22, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Alphanumeric
LCD (Grove - UART) component
Standard alphanumeric LCD based on the Grove display module.
Please click here to download the component source project: FC_Comp_Source_LCD_Grove_Uart.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Grove_Uart.fcfx
Fc9-comp-macro.png ClearSim
Fc9-comp-macro.png PrintString
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png BacklightControl
Fc9-u8-icon.png - BYTE State
0=Backlight Off, 1=Backlight On
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE position
Number of positions to scroll the display
Fc9-u8-icon.png - BYTE direction
Direction to scroll the display: 0=Left, 1=Right
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
Fc9-comp-macro.png Start
Startup routine required by the hardware device.
Fc9-conn-icon.png LCD Configuration
Fc9-type-16-icon.png Rows
Fc9-type-16-icon.png Columns
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-7-icon.png Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Fc9-type-1-icon.png Display Background
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
