Component: MULTIUART (SPI2UART) (Comms: Interface)
Revision as of 15:23, 20 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Interface
MULTIUART component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
Please click here to download the component source project: FC_Comp_Source_MULTIUART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MULTIUART.fcfx
Simple test program
ReceiveByte
Returns the first received byte held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
- BYTE UART
UART Index Range: 0-3
TransmitString
Adds a byte to the transmit queue for the selected channel.
- BYTE UART
- STRING Data
SetBaud
- BYTE UART
- BYTE Baud
TransmitByte
- BYTE UART
- BYTE Data
CheckRx
Returns the number of received bytes held in queue for the selected channel.
- BYTE UART
CheckTx
Returns the number of bytes held in the transmit queue for the selected channel.
- BYTE UART
ReceiveString
Returns a string of received bytes held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
- BYTE UART
- BYTE NumBytes
- STRING Return
Activates the SPI peripheral and claims control over the I/O pins.
Bus Settings
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Label used to identify the component on the panel.
API
ReceiveByte
- BYTE UART
TransmitString
- BYTE UART
- STRING Data
SetBaud
- BYTE UART
- BYTE Baud
TransmitByte
- BYTE UART
- BYTE Data
CheckRx
- BYTE UART
CheckTx
- BYTE UART
ReceiveString
- BYTE UART
- BYTE NumBytes
- STRING Return
Bus Settings
Prescale
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
API
ReceiveByte
- BYTE UART
TransmitString
- BYTE UART
- STRING Data
SetBaud
- BYTE UART
- BYTE Baud
TransmitByte
- BYTE UART
- BYTE Data
CheckRx
- BYTE UART
CheckTx
- BYTE UART
ReceiveString
- BYTE UART
- BYTE NumBytes
- STRING Return
Bus Settings
Prescale
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
API
