Author
Matrix TSL
Version
1.5
Category
Comms: Networking
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
Please click here to download the component source project: FC_Comp_Source_NetworkComms.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_NetworkComms.fcfx
Connect
Connects to an IP address as a client on the specified port. Some TCP/IP modules (RPI and ESP8266) will accept a URL instead of an IP address. Returns: 0=Fail, 1=OK
- STRING
Address
IP address as a string e.g. "192.168.1.1" or URL on some TCP/IP modules
- UINT
Port
Port number to connect to.
- BOOL
Receive
Attempts to receive up to a specified number of bytes from the active connection. Returns the number of bytes received.
- STRING
Data
Data Array to store the data into.
- UINT
Count
Maximum number of bytes to read
- UINT
Timeout
Maximum time to wait in mS (approx)
- UINT
Send
Sends the specified number of bytes via the active connection. Returns the number of bytes sent, 0=Fail.
- STRING
Data
Array containing the data to send
- UINT
Count
Number of bytes to send from the data array
- UINT
Listen
Bind the socket to a port on the local host and set to listen mode. First Open a Socket on the local host Returns: 0=Fail, 1=OK
- UINT
Port
Port number to listen on.
- BOOL
SocketOpen
Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK
- BOOL
SocketClose
Closes the current socket connection
AcceptOpen
Required for systems where there can be multiple incoming threads Returns 1 if there is incoming comms requiring a new thread, else returns 0
- BYTE
AcceptClose
Goes with the AcceptOpen function to close the new thread handle.
Initialises the network communications component.
LinkTo
TCP IP Channel
Allows for several parallel TCP/IP communications channels to be active at once by selecting unique TCP IP channels for each Network Comms component. Default 0.
Status
Simulation Control
Allows the user to decide what happens when simulating. Simulation DLL forces all simulated TCP/IP comms to go directly via the simulation DLL bypassing any additional components. Component simulation forces the attached component to provide the simulation and maybe other aspects such as SPI/I2C communications.
Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
IP Address
IP Address of the selected network interface.
Connect
- STRING
Address
- UINT
Port
- BOOL
Receive
- STRING
Data
- UINT
Count
- UINT
Timeout
- UINT
Send
- STRING
Data
- UINT
Count
- UINT
Listen
- UINT
Port
- BOOL
SocketOpen
- BOOL
SocketClose
AcceptOpen
- BYTE
AcceptClose
LinkTo
TCP IP Channel
Status
Simulation Control
Network Interface
IP Address
Connect
- STRING
Address
- UINT
Port
- BOOL
Receive
- STRING
Data
- UINT
Count
- UINT
Timeout
- UINT
Send
- STRING
Data
- UINT
Count
- UINT
Listen
- UINT
Port
- BOOL
SocketOpen
- BOOL
SocketClose
AcceptOpen
- BYTE
AcceptClose
LinkTo
TCP IP Channel
Status
Simulation Control
Network Interface
IP Address
