| Author
Matrix Ltd
| Version
1.0
| Category
Test Equipment
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
Please click here to download the component source project: FC_Comp_Source_PS2000.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_PS2000.fcsx
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
Velleman and Picoscope Demo
ps2000_get_timebase
| Returns details associated with the selected timebase index
- INT
Handle
| the handle of the required device.
- INT
timebase
| The ps2000a API allows you to select any of 2 32 different timebases based on a maximum sampling rate of 1 GS/s.
- LONG
no_of_samples
| number of samples required
- LONG
time_interval
| time interval between readings at the selected timebase. Use NULL if not required.
- INT
time_units
- INT
oversample
| not used.
- LONG
max_samples
| on exit, the maximum number of samples available.
- INT
ps2000_open_unit_progress
| This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope.
- INT
handle
- INT
Progress
- INT
ps2000_flash_led
| This function flashes the LED on the front of the scope without blocking the calling thread.
- INT
handle
| handle of the scope device
- INT
ps2000_stop
| This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data.
- INT
Handle
- INT
ps2000_get_unit_info
| This function retrieves information about the specified oscilloscope.
- INT
Handle
| the handle of the device
- STRING
info_string
| unit information string
- INT
string_length
| the maximum number of chars in the string
- INT
info_line
| a number specifying what information is required. 0=DriverVersion / 1=USBVersion / 2=HardwareVersion / 3=VariantInfo / 4=BatchAndSerial / 5=CalDate / 6=KernelVersion / 7=DigHardwareVersion / 8=AnHardwareVersion
- INT
ps2000_set_channel
| This function specifies whether an input channel is to be enabled, its input coupling type, voltage range, analog offset and bandwidth limit.
- INT
handle
| Handle of the device
- INT
channel
| the channel to be configured. The values are: 0=ChanA / 1=ChanB
- INT
enabled
| whether or not to enable the channel. The values are: 0=Disable / 1=Enable
- INT
dc
| the impedance and coupling type. Values: 0=AC / 1=DC
- INT
range
| the input voltage range: 0=50mV / 1=100mV / 2=200mV / 3=500mV / 4=1V / 5=2V / 6=5V / 7=10V / 8=20V
- INT
ps2000_get_times_and_values
- INT
Handle
- LONG
times
- INT
buffer_a
- INT
buffer_b
- INT
buffer_c
- INT
buffer_d
- INT
overflow
- INT
time_units
- LONG
no_of_samples
- LONG
ps2000_set_trigger
- INT
handle
- INT
source
- INT
threshold
- INT
direction
- INT
delay
- INT
auto_trigger_ms
- INT
ps2000_set_sig_gen_built_in
| sets up the signal generator to produce a signal from a list of built-in waveforms
- INT
Handle
| Handle to the device
- LONG
Offset_uV
| the voltage offset, in microvolts, to be applied to the waveform
- ULONG
pk2pk_uV
| the peak-to-peak voltage, in microvolts, of the waveform
- INT
waveType
| the type of waveform to be generated. 0=Sine / 1=Square / 2=Triangle / 3=RampUp / 4=RampDown / 5=Sinc / 6=Gaus / 7=HalfSine / 8=DC
- FLOAT
startFrequency
| the frequency that the signal generator will initially produce
- FLOAT
stopFrequency
| the frequency at which the sweep reverses direction or returns to initial
- FLOAT
increment
| the amount of frequency increase or decrease in sweep mode
- FLOAT
dwellTime
| the time for which the sweep stays at each frequency, in seconds
- INT
sweepType
| whether the frequency will sweep from startFrequency to stopFrequency. 0=Up, 1=Down, 2=UpDown, 3=DownUp
- ULONG
sweeps
| produce number of cycles specified by shots
- INT
ps2000_close_unit
| This function shuts down an oscilloscope.
- INT
Handle
| The handle of the scope device to be closed
- INT
ps2000_run_block
| This function starts collecting data in block mode.
- INT
handle
- LONG
no_of_samples
- INT
timebase
- INT
oversample
- LONG
time_indisposed_ms
- INT
ps2000_get_values
| This function returns block-mode data, with or without downsampling.
- INT
Handle
- INT
buffer_a
| Start point for data collection
- INT
buffer_b
| Number of samples
- INT
buffer_c
| Down sample ratio
- INT
buffer_d
| Down sample mode : 0=None / 1=Aggregate / 2=Decimate / 4=Average
- INT
overflow
| Flags to indicate if an overflow has occurred
- LONG
no_of_samples
- LONG
ps2000_ready
- INT
Handle
- INT
ps2000_open_unit_async
| This function opens a scope without blocking the calling thread.
- INT
ps2000_open_unit
| Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open
- INT
ps2000_get_timebase
- INT
Handle
- INT
timebase
- LONG
no_of_samples
- LONG
time_interval
- INT
time_units
- INT
oversample
| not used.
- LONG
max_samples
- INT
- INT
handle
- INT
Progress
- INT
ps2000_flash_led
- INT
handle
- INT
ps2000_stop
- INT
Handle
- INT
- INT
Handle
- STRING
info_string
- INT
string_length
- INT
info_line
- INT
ps2000_set_channel
- INT
handle
- INT
channel
- INT
enabled
- INT
dc
- INT
range
- INT
- INT
Handle
- LONG
times
- INT
buffer_a
- INT
buffer_b
- INT
buffer_c
- INT
buffer_d
- INT
overflow
- INT
time_units
- LONG
no_of_samples
- LONG
ps2000_set_trigger
- INT
handle
- INT
source
- INT
threshold
- INT
direction
- INT
delay
- INT
auto_trigger_ms
- INT
- INT
Handle
- LONG
Offset_uV
- ULONG
pk2pk_uV
- INT
waveType
- FLOAT
startFrequency
- FLOAT
stopFrequency
- FLOAT
increment
- FLOAT
dwellTime
- INT
sweepType
- ULONG
sweeps
- INT
ps2000_close_unit
- INT
Handle
- INT
ps2000_run_block
- INT
handle
- LONG
no_of_samples
- INT
timebase
- INT
oversample
- LONG
time_indisposed_ms
- INT
ps2000_get_values
- INT
Handle
- INT
buffer_a
- INT
buffer_b
| Number of samples
- INT
buffer_c
| Down sample ratio
- INT
buffer_d
- INT
overflow
- LONG
no_of_samples
- LONG
ps2000_ready
- INT
Handle
- INT
- INT
ps2000_open_unit
- INT
ps2000_get_timebase
- INT
Handle
- INT
timebase
- LONG
no_of_samples
- LONG
time_interval
- INT
time_units
- INT
oversample
| not used.
- LONG
max_samples
- INT
- INT
handle
- INT
Progress
- INT
ps2000_flash_led
- INT
handle
- INT
ps2000_stop
- INT
Handle
- INT
- INT
Handle
- STRING
info_string
- INT
string_length
- INT
info_line
- INT
ps2000_set_channel
- INT
handle
- INT
channel
- INT
enabled
- INT
dc
- INT
range
- INT
- INT
Handle
- LONG
times
- INT
buffer_a
- INT
buffer_b
- INT
buffer_c
- INT
buffer_d
- INT
overflow
- INT
time_units
- LONG
no_of_samples
- LONG
ps2000_set_trigger
- INT
handle
- INT
source
- INT
threshold
- INT
direction
- INT
delay
- INT
auto_trigger_ms
- INT
- INT
Handle
- LONG
Offset_uV
- ULONG
pk2pk_uV
- INT
waveType
- FLOAT
startFrequency
- FLOAT
stopFrequency
- FLOAT
increment
- FLOAT
dwellTime
- INT
sweepType
- ULONG
sweeps
- INT
ps2000_close_unit
- INT
Handle
- INT
ps2000_run_block
- INT
handle
- LONG
no_of_samples
- INT
timebase
- INT
oversample
- LONG
time_indisposed_ms
- INT
ps2000_get_values
- INT
Handle
- INT
buffer_a
- INT
buffer_b
| Number of samples
- INT
buffer_c
| Down sample ratio
- INT
buffer_d
- INT
overflow
- LONG
no_of_samples
- LONG
ps2000_ready
- INT
Handle
- INT
- INT
ps2000_open_unit
- INT
