Component: Serial EEPROM (93C46) (EEPROM)
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category EEPROM
Serial EEPROM (93C46) component
A simple example showing the bare bones used to create a component based on SPI communications. ORG pin must be connected to GND
Please click here to download the component source project: FC_Comp_Source_Serial_EEPROM_(93C46).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(93C46).fcfx
Erase
- BYTE Address
Read
8bit mode address = 0 to 128 Data = 0 to 255 16bit mode address = 0 to 64 Data = 0 to 65535
- BYTE address
Write
- BYTE address
- UINT Value
SendBits
A simple example showing a generic way to write a register using I2C.
- UINT value
- BYTE length
EraseAll
Mode
CS
EEPROM pin 1
SK
EEPROM pin 2
DI
EEPROM pin 3
DO
EEPROM pin 4
Operations
Control Codes
Erase
- BYTE Address
Read
- BYTE address
Write
- BYTE address
- UINT Value
SendBits
- UINT value
- BYTE length
EraseAll
Mode
CS
EEPROM pin 1
SK
EEPROM pin 2
DI
EEPROM pin 3
DO
EEPROM pin 4
Operations
Control Codes
Erase
- BYTE Address
Read
- BYTE address
Write
- BYTE address
- UINT Value
SendBits
- UINT value
- BYTE length
EraseAll
Mode
CS
EEPROM pin 1
SK
EEPROM pin 2
DI
EEPROM pin 3
DO
EEPROM pin 4
Operations
Control Codes
