Component: Sound Sensor (Grove 101020023) (101020023) (Audio)
Revision as of 15:24, 20 January 2023 by Wiki bot (talk | contribs)
Category Audio
Sound Sensor (Grove 101020023) component
The Sound sensor module is a simple microphone. Based on the power amplifier LM386 and the electret microphone, it can be used to detect the sound strength of the environment.
Please click here to download the component source project: FC_Comp_Source_Sound_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sound_Sensor.fcfx
Fc9-comp-macro.png GetString
Reads the ADC as a direct voltage and returns as as tring
Fc9-comp-macro.png GetAverageByte
Function call to read the ADC as a byte average sample over time
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
Number of micro seconds in between taking each sample
Fc9-comp-macro.png GetAverageInt
Function call to read the ADC as a full width average sample over time
Fc9-comp-macro.png GetVoltage
Fc9-comp-macro.png GetInt
Blocking call to read the ADC at full bit depth
Fc9-comp-macro.png GetByte
Blocking call to read the ADC as a byte
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Tang Color
Colour of the moving part of the slider.
Fc9-type-1-icon.png Marker Color
Colour of the marker line across the slider tang.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-14-icon.png Aquisition cycles
