Author
Matrix Ltd.
Version
2.0
Category
Comms: Networking
TCP/IP Dummy component
TCP/IP component designed to work with the WIZ810MJ module from Wiznet, as used on version 2 EB023 E-block and the MIAC Industrial Addon module.
Please click here to download the component source project: FC_Comp_Source_TCPIP_EB023-00-2_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_EB023-00-2_Dummy.fcfx
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
Specifies the communications channel 0-3
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
Specifies the value of the first byte
- BYTE
Byte2
Specifies the value of the second byte
- BYTE
Byte3
Specifies the value of the third byte
- BYTE
Byte4
Specifies the value of the fourth byte
- BYTE
SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
First Byte of IP address
- BYTE
IP1
Second Byte of IP address
- BYTE
IP2
Third Byte of IP address
- BYTE
IP3
Fourth Byte of IP address
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE
- STRING
Data
Data byte to append to Tx buffer.
- BYTE
Length
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
Specifies the byte index to return
- BYTE
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
Specifies how many bytes to skip
MIAC_Module_SetData
- BYTE
Count
- BYTE
D0
- BYTE
D1
- BYTE
D2
- BYTE
D3
- BYTE
D4
- BYTE
D5
CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE
- BYTE
Protocol
Specifies which IP protocol to use
- BYTE
Broadcast
Allows broadcast type packets to be sent and received
- BYTE
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE
- BYTE
Dst_IP0
Specifies the first byte of an IP address
- BYTE
Dst_IP1
Specifies the second byte of an IP address
- BYTE
Dst_IP2
Specifies the third byte of an IP address
- BYTE
Dst_IP3
Specifies the fourth byte of an IP address
- UINT
Dst_Port
Destination Port
- BYTE
MIAC_Module_GetData
- BYTE
Index
- BYTE
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
MIAC_Module_Message
- UINT
CAN_ID
- UINT
CMD_ID
- BYTE
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE
- UINT
Src_Port
Port Number
- BYTE
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
Specifies the value of the fifth byte
- BYTE
Byte6
Specifies the value of the sixth byte
- BYTE
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
RxReadString
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
- STRING
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE
- UINT
Src_Port
Port Number
- BYTE
RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE
- BYTE
MIAC_Module_PushData
- BYTE
Data
TxSendByte
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE
- BYTE
Data
TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE
TxSendByte_Sim
- BYTE
- BYTE
Data
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
Destination Port
- BYTE
RxReadByte_Sim
- BYTE
- BYTE
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
RxFlushData_Sim
- BYTE
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- UINT
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
CreateUDPSocket_Sim
- BYTE
- UINT
Src_Port
Port Number
- BYTE
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
SetMACAddress
This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
- BYTE
MAC0
First Byte of address
- BYTE
MAC1
Second Byte of address
- BYTE
MAC2
Third Byte of address
- BYTE
MAC3
Fourth Byte of address
- BYTE
MAC4
- BYTE
MAC5
Fifth Byte of address
RxMatch_4_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
RxDataSize_Sim
- BYTE
- BYTE
SetSubnetMask
This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
RxMatch_2_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
RxMatchMyMAC_Sim
- BYTE
- BYTE
TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
GetSocketStatus
This returns the state of the requested channel's socket.
- BYTE
- BYTE
- BYTE
SetGateway
This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendMyIP
- BYTE
RxMatchMyIP
- BYTE
- BYTE
RxMatch_4_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
SetMyIP
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendString
- BYTE
- STRING
Data
- BYTE
Length
RxReadHeader
- BYTE
- BYTE
Idx
- BYTE
RxSkipBytes
- BYTE
- BYTE
Count
MIAC_Module_SetData
- BYTE
Count
- BYTE
D0
- BYTE
D1
- BYTE
D2
- BYTE
D3
- BYTE
D4
- BYTE
D5
CreateIPSocket
- BYTE
- BYTE
Protocol
- BYTE
Broadcast
- BYTE
SetDestination
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
Destination Port
- BYTE
MIAC_Module_GetData
- BYTE
Index
- BYTE
TxStart
- BYTE
MIAC_Module_Message
- UINT
CAN_ID
- UINT
CMD_ID
- BYTE
RxReadByte
- BYTE
- BYTE
CreateUDPSocket
- BYTE
- UINT
Src_Port
Port Number
- BYTE
RxMatch_6_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
- BYTE
Byte6
- BYTE
RxMatch_2_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
TxEnd
- BYTE
RxReadString
- BYTE
- BYTE
Length
- STRING
CreateTCPSocket
- BYTE
- UINT
Src_Port
Port Number
- BYTE
RxDataAvailable
- BYTE
- BYTE
- BYTE
Data
TxSendByte
- BYTE
- BYTE
Data
TCPListen
- BYTE
TxSendByte_Sim
- BYTE
- BYTE
Data
RxFlushData
- BYTE
TCPConnect
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
Destination Port
- BYTE
RxReadByte_Sim
- BYTE
- BYTE
RxMatchMyMAC
- BYTE
- BYTE
RxFlushData_Sim
- BYTE
RxDataSize
- BYTE
- UINT
CreateMACSocket
- BYTE
Promiscuous
- BYTE
Broadcast
- BYTE
Error
- BYTE
CreateUDPSocket_Sim
- BYTE
- UINT
Src_Port
Port Number
- BYTE
TxSendMyMAC
- BYTE
SetMACAddress
- BYTE
MAC0
- BYTE
MAC1
- BYTE
MAC2
- BYTE
MAC3
- BYTE
MAC4
- BYTE
MAC5
RxMatch_4_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
RxDataSize_Sim
- BYTE
- BYTE
SetSubnetMask
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
RxMatch_2_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
RxMatchMyMAC_Sim
- BYTE
- BYTE
TCPClose
- BYTE
GetSocketStatus
- BYTE
- BYTE
- BYTE
SetGateway
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendMyIP
- BYTE
RxMatchMyIP
- BYTE
- BYTE
RxMatch_4_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
SetMyIP
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendString
- BYTE
- STRING
Data
- BYTE
Length
RxReadHeader
- BYTE
- BYTE
Idx
- BYTE
RxSkipBytes
- BYTE
- BYTE
Count
MIAC_Module_SetData
- BYTE
Count
- BYTE
D0
- BYTE
D1
- BYTE
D2
- BYTE
D3
- BYTE
D4
- BYTE
D5
CreateIPSocket
- BYTE
- BYTE
Protocol
- BYTE
Broadcast
- BYTE
SetDestination
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
Destination Port
- BYTE
MIAC_Module_GetData
- BYTE
Index
- BYTE
TxStart
- BYTE
MIAC_Module_Message
- UINT
CAN_ID
- UINT
CMD_ID
- BYTE
RxReadByte
- BYTE
- BYTE
CreateUDPSocket
- BYTE
- UINT
Src_Port
Port Number
- BYTE
RxMatch_6_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
- BYTE
Byte6
- BYTE
RxMatch_2_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
TxEnd
- BYTE
RxReadString
- BYTE
- BYTE
Length
- STRING
CreateTCPSocket
- BYTE
- UINT
Src_Port
Port Number
- BYTE
RxDataAvailable
- BYTE
- BYTE
- BYTE
Data
TxSendByte
- BYTE
- BYTE
Data
TCPListen
- BYTE
TxSendByte_Sim
- BYTE
- BYTE
Data
RxFlushData
- BYTE
TCPConnect
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
Destination Port
- BYTE
RxReadByte_Sim
- BYTE
- BYTE
RxMatchMyMAC
- BYTE
- BYTE
RxFlushData_Sim
- BYTE
RxDataSize
- BYTE
- UINT
CreateMACSocket
- BYTE
Promiscuous
- BYTE
Broadcast
- BYTE
Error
- BYTE
CreateUDPSocket_Sim
- BYTE
- UINT
Src_Port
Port Number
- BYTE
TxSendMyMAC
- BYTE
SetMACAddress
- BYTE
MAC0
- BYTE
MAC1
- BYTE
MAC2
- BYTE
MAC3
- BYTE
MAC4
- BYTE
MAC5
RxMatch_4_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
RxDataSize_Sim
- BYTE
- BYTE
SetSubnetMask
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
RxMatch_2_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
RxMatchMyMAC_Sim
- BYTE
- BYTE
TCPClose
- BYTE
GetSocketStatus
- BYTE
- BYTE
- BYTE
SetGateway
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
