Component: Timer Free (Timing)
Revision as of 15:25, 20 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Timing
Timer Free component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
Please click here to download the component source project: FC_Comp_Source_TimerComponentFree.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponentFree.fcfx
Here is a basic example showing the operation of the timer component used to time a section of code or the duration of a specific event.
Timer Example
GetCountSeconds
Returns the count value as a number of whole seconds, rounded down to the nearest second
- ULONG Return
StartCounter
Starts the timer counting.
- BOOL ResetCounters
Range: 0-1 where 0=Do Not Reset and 1=Reset
GetCountString
Returns the count value as a floating point string in seconds.
- BYTE Precision
Number of decimal places to display in string
- STRING Return
GetCountMicroSeconds
Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond
- ULONG Return
GetCountMilliseconds
Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond
- ULONG Return
StopCounter
Stops the timer counting.
ResetCounter
GetCountReal
Returns the count value as a floating point value in seconds.
- FLOAT Return
GetRawCount
- ULONG Return
Timer
Timer Peripheral to use to monitor the passage of time.
Bit Depth
Number of bits in the timer peripheral. 8-bit timers can count from 0-255 before overflowing. 16-bit timers can count from 0 to 65535 before overflowing.
Instruction Rate
Rollover Frequency
Rollover Time
Max Time Measurement
Max time in seconds that we can measure before rolling over and starting again.
Timer Delay (ms)
Number of milliseconds between timer events which increment the simulated timer counter variable. 10ms will yield the highest resolution. Values less than this will likely just increase the error and making the timer run slow. Higher delays will yield greater accuracy.
Decimal Points
GetCountSeconds
- ULONG Return
StartCounter
GetCountString
- BYTE Precision
- STRING Return
- ULONG Return
- ULONG Return
StopCounter
ResetCounter
GetCountReal
- FLOAT Return
GetRawCount
- ULONG Return
Timer
Bit Depth
Instruction Rate
Rollover Frequency
Rollover Time
Timer Delay (ms)
Decimal Points
GetCountSeconds
- ULONG Return
StartCounter
GetCountString
- BYTE Precision
- STRING Return
- ULONG Return
- ULONG Return
StopCounter
ResetCounter
GetCountReal
- FLOAT Return
GetRawCount
- ULONG Return
Timer
Bit Depth
Instruction Rate
Rollover Frequency
Rollover Time
Timer Delay (ms)
Decimal Points
