Component: PIC32 Core Timer (Timing)
| Author | MatrixTSL |
| Category | Timing |
PIC32 Core Timer component
Allows for easy and accurate timings using the built in Core timer on the PIC32 devices.
Please click here to download the component source project: FC_Comp_Source_TimerComponentPIC32Core.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponentPIC32Core.fcfx
| Start_S | |
| A none blocking function that allows for accurate delays to be specified in seconds using the core timer. | |
| Delay | |
| Start_InstructionCount | |
| A none blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer. | |
| Delay | |
| Delay_S | |
| A blocking function that allows for accurate delays to be specified in seconds using the core timer. | |
| Delay | |
| Start_Ms | |
| A none blocking function that allows for accurate delays to be specified in milliseconds using the core timer. | |
| Delay | |
| Start_Us | |
| A none blocking function that allows for accurate delays to be specified in micro seconds using the core timer. | |
| Delay | |
| Delay_Ms | |
| A blocking function that allows for accurate delays to be specified in milliseconds using the core timer. | |
| Delay | |
| Delay_InstructionCount | |
| A blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer. | |
| Delay | |
| Start_Ns | |
| A none blocking function that allows for accurate delays to be specified in nano seconds using the core timer. | |
| Delay | |
| Delay_Us | |
| A blocking function that allows for accurate delays to be specified in micro seconds using the core timer. | |
| Delay | |
| Delay_Ns | |
| A blocking function that allows for accurate delays to be specified in nano seconds using the core timer. | |
| Delay | |
| Check_Counter | |
| Checks to see if the counter time is elapsed. Used in conjunction with the Start_ component macros. Returns 1 if complete or 0 if still counting. | |
| Properties |
| Start_S | |
| Delay | |
| Delay | |
| Delay_S | |
| Delay | |
| Start_Ms | |
| Delay | |
| Start_Us | |
| Delay | |
| Delay_Ms | |
| Delay | |
| Delay | |
| Start_Ns | |
| Delay | |
| Delay_Us | |
| Delay | |
| Delay_Ns | |
| Delay | |
| Check_Counter | |
| Properties |
| Start_S | |
| Delay | |
| Delay | |
| Delay_S | |
| Delay | |
| Start_Ms | |
| Delay | |
| Start_Us | |
| Delay | |
| Delay_Ms | |
| Delay | |
| Delay | |
| Start_Ns | |
| Delay | |
| Delay_Us | |
| Delay | |
| Delay_Ns | |
| Delay | |
| Check_Counter | |
| Properties |
