Author
Matrix Ltd.
Version
2.0
Category
Comms: System
Visi (4DSystems) component
A way of interacting with the VISI interface designed by 4D systems. VISI firmware must be pre-loaded onto the SD card connected to the display to allow everything to work correctly.
Please click here to download the component source project: FC_Comp_Source_API_Display_Visi4D.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_Display_Visi4D.fcfx
VisiWriteString
Writes a string to a specific Visi object. Returns 0 for a succesful write operation.
- BYTE
StringIndex
- STRING
StringData
- BYTE
VisiWriteObject
Writes a value to a specific Visi object. Returns 0 for a succesful write operation.
- BYTE
ObjectID
- BYTE
ObjectIndex
- UINT
Value
- BYTE
ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
- BYTE
NewBaud
VisiReceive
Waits for an incoming Visi Report Object or Report Event to be sent from the display. A detected incoming message returns 0 and can be read using the VisiReadByteFromMessage macro.
- BYTE
VisiWriteContrast
Updates the display contrast. Returns 0 for a succesful write operation.
- BYTE
Contrast
Range 0-15, 0=Backlight Off
- BYTE
VisiWriteVolume
Updates the display volume. Returns 0 for a succesful write operation.
- BYTE
Volume
Range 8-127
- BYTE
Reads a byte from a succesful VisiReceive macro. Index: 0=Command, 1=ObjectID, 2=ObjectIndex, 3=ValueMSB, 4=ValueLSB
- BYTE
Index
- BYTE
VisiReadObject
Reads the value from a specific Visi object. Returns 0 for a sucessful read. Use the VisiReadByteFromMessage macro to pull out the incoming data.
- BYTE
ObjectID
- BYTE
ObjectIndex
- BYTE
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
Comms Settings
Baud Options
TX
RX
Label shown on the communications flasher component
Console Columns
Data Source
VisiWriteString
- BYTE
StringIndex
- STRING
StringData
- BYTE
VisiWriteObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- UINT
Value
- BYTE
ChangeHWBaud
- BYTE
NewBaud
VisiReceive
- BYTE
VisiWriteContrast
- BYTE
Contrast
- BYTE
VisiWriteVolume
- BYTE
Volume
Range 8-127
- BYTE
- BYTE
Index
- BYTE
VisiReadObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- BYTE
Comms Settings
Baud Options
TX
RX
Console Columns
Data Source
VisiWriteString
- BYTE
StringIndex
- STRING
StringData
- BYTE
VisiWriteObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- UINT
Value
- BYTE
ChangeHWBaud
- BYTE
NewBaud
VisiReceive
- BYTE
VisiWriteContrast
- BYTE
Contrast
- BYTE
VisiWriteVolume
- BYTE
Volume
Range 8-127
- BYTE
- BYTE
Index
- BYTE
VisiReadObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- BYTE
Comms Settings
Baud Options
TX
RX
Console Columns
Data Source
VisiWriteString
- BYTE
StringIndex
- STRING
StringData
- BYTE
VisiWriteObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- UINT
Value
- BYTE
ChangeHWBaud
- BYTE
NewBaud
VisiReceive
- BYTE
VisiWriteContrast
- BYTE
Contrast
- BYTE
VisiWriteVolume
- BYTE
Volume
Range 8-127
- BYTE
- BYTE
Index
- BYTE
VisiReadObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- BYTE
Comms Settings
Baud Options
TX
RX
Console Columns
Data Source
VisiWriteString
- BYTE
StringIndex
- STRING
StringData
- BYTE
VisiWriteObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- UINT
Value
- BYTE
ChangeHWBaud
- BYTE
NewBaud
VisiReceive
- BYTE
VisiWriteContrast
- BYTE
Contrast
- BYTE
VisiWriteVolume
- BYTE
Volume
Range 8-127
- BYTE
- BYTE
Index
- BYTE
VisiReadObject
- BYTE
ObjectID
- BYTE
ObjectIndex
- BYTE
Comms Settings
Baud Options
TX
RX
Console Columns
Data Source
