Component: API UART Dummy (API Slave Devices)
Revision as of 09:54, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API UART Dummy component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_API_UART_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_API_UART_Dummy.fcfx
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
Fc9-comp-macro.png UARTCheckRX
Fc9-comp-macro.png UARTInitialise
Fc9-comp-macro.png IOSetOutputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-53
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png IOGetInputPin
Range: 0-19
Fc9-comp-macro.png UARTSend
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Range: 0-53
Range: 0-1
Range: 0-19
Range: 0-53
Range: 0-1
Range: 0-19
Range: 0-53
Range: 0-1
Range: 0-19
Range: 0-53
Range: 0-1
Range: 0-19
