| Author
Matrix Ltd
| Version
1.3
| Category
Controls
Control Knob component
Rotary control designed for SCADA. Has customisable value markings around the control. Simulation only.
Please click here to download the component source project: FC_Comp_Source_ControlKnob.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ControlKnob.fcfx
GetValue
| Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control" mode.
- FLOAT
SetValue
| Set the pointer to the given value on the scale. Returns the angle required to point at the given value.
- FLOAT
Value
| The value on the scale to move the pointer to.
- FLOAT
Range
Minimum
| The minimum value that the knob will output (fully counter_clockwise)
Maximum
| The maximum value that the knob will output (fully clockwise)
Startup State
| Sets the initial value when loading the project or when the runtime starts.
Default Value
| The default value used on initialise or runtime start.
Title
Show Title
| Decides if the component title is shown
Title Colour
| Title Label Color
Title Text
| Title Label Text
Title Scale
| Controls the size of the title text on the panel, default 1.2
Title Offset
| Distance above component center to draw the title
Show Label
| Decides if a label is shown detailing current setting of the control knob.
Label Colour
| Sets the label colour
Label Units
| Adds a unit to the end of the label
Label Decimal Points
| Number of decinal points to draw on the label
Label Scale
| Sets the size of the label on the panel, default 1.0
Label Offset
| Distance above component center to draw the label
Numeric Labels
Decimals
| How many decimal places to show on the number labels.
Text Size %
| Height of the number label text.
Font
| Font for the number labels.
Divisions
| Number of labelled positions around the knob.
Subdivisions
| Number of divisions between the numbered ones.
Scheme
BG Color
| Background colour behind the knob labelling - may be transparent.
Positive Color
| Colour for number labels which are less than zero.
Negative Color
| Colour for number labels which are greater than zero.
Pointer Colour
Buttons
Show Buttons
| Controls if the adjustment buttons are shown on the scale arc or not.
Button Color
| Color for the component label text.
Adjustment Value
| Sets the button adjustment value, will round the value to the nearest whole adjustment. For example with an adjustment of 1,0 the adjustment buttons will jump to the next whole number.
GetValue
- FLOAT
SetValue
- FLOAT
Value
- FLOAT
Range
Minimum
Maximum
Startup State
Default Value
Title
Show Title
Title Colour
| Title Label Color
Title Text
| Title Label Text
Title Scale
Title Offset
Show Label
Label Colour
Label Units
Label Scale
Label Offset
Numeric Labels
Decimals
Text Size %
Font
Divisions
Subdivisions
Scheme
BG Color
Positive Color
Negative Color
Pointer Colour
Buttons
Show Buttons
Button Color
Adjustment Value
GetValue
- FLOAT
SetValue
- FLOAT
Value
- FLOAT
Range
Minimum
Maximum
Startup State
Default Value
Title
Show Title
Title Colour
| Title Label Color
Title Text
| Title Label Text
Title Scale
Title Offset
Show Label
Label Colour
Label Units
Label Scale
Label Offset
Numeric Labels
Decimals
Text Size %
Font
Divisions
Subdivisions
Scheme
BG Color
Positive Color
Negative Color
Pointer Colour
Buttons
Show Buttons
Button Color
Adjustment Value
GetValue
- FLOAT
SetValue
- FLOAT
Value
- FLOAT
Range
Minimum
Maximum
Startup State
Default Value
Title
Show Title
Title Colour
| Title Label Color
Title Text
| Title Label Text
Title Scale
Title Offset
Show Label
Label Colour
Label Units
Label Scale
Label Offset
Numeric Labels
Decimals
Text Size %
Font
Divisions
Subdivisions
Scheme
BG Color
Positive Color
Negative Color
Pointer Colour
Buttons
Show Buttons
Button Color
Adjustment Value
GetValue
- FLOAT
SetValue
- FLOAT
Value
- FLOAT
Range
Minimum
Maximum
Startup State
Default Value
Title
Show Title
Title Colour
| Title Label Color
Title Text
| Title Label Text
Title Scale
Title Offset
Show Label
Label Colour
Label Units
Label Scale
Label Offset
Numeric Labels
Decimals
Text Size %
Font
Divisions
Subdivisions
Scheme
BG Color
Positive Color
Negative Color
Pointer Colour
Buttons
Show Buttons
Button Color
Adjustment Value
