| Author
| Version
1.0
| Category
Electrical
Current Sensor (ACS7xx) component
ACS7XX range of +/- 5, 20, 30, 50, 100, 150 & 200A current sensors
Please click here to download the component source project: FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Current_Sensor_ACS7xx.fcfx
Simple example showing how to use the simulation dial components as a meter display for use in monitoring type applications.
Meters
Current
| Current reading in amps
- FLOAT
VoltgeADC
| Reads the Voltage of the ADC pin for diagnostic purposes. With no current flowing through the sensor, the voltage reading should be 2.50V. If that is out, then enter precise VDD within properties
- FLOAT
Device
Type
VDD
Offset current adjust (Amps)
| Offset current adjusts the curent output when comparing to a current monitor. For example current from the componet shows 2.0 Amps and curent monitor shows 1.5 Amps. For the current offset enter -0.5
| Analogue Input Channel - Which pin is the analogue input connected to?
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Current
- FLOAT
VoltgeADC
- FLOAT
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
Current
- FLOAT
VoltgeADC
- FLOAT
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
Current
- FLOAT
VoltgeADC
- FLOAT
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
Current
- FLOAT
VoltgeADC
- FLOAT
Device
Type
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
