Component: Touch Pads (EBM013) (EBM Modules)
Revision as of 09:56, 27 January 2023 by Wiki bot (talk | contribs)
Category EBM Modules
Touch Pads component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
Please click here to download the component source project: FC_Comp_Source_EBM013v5.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM013v5.fcfx
Sample program using the EBM013 - Touch Pads sensor.
Sensors are first calibrated and then can be read as digital switches
EBM013 Example
GetTouchValue
Samples the touch sensor ADC value and returns it Always samples both channels, but only returns the chosen channel
- BOOL Switch
Select Switch. Switch 1 = 0, Switch 2 = 1
GetTouchPressed
Returns non-zero if touch detected
- BOOL Switch
- UINT OffValue
- BYTE Threshold
Provide the threshold value for the pad to be considered touched
- BOOL Return
Channel 1
ADC Channel number
Channel 2
Simulation Properties
Switch 1
On Value
Off Value
Switch 2
On Value
Off Value
GetTouchValue
- BOOL Switch
GetTouchPressed
- BOOL Switch
- UINT OffValue
- BYTE Threshold
- BOOL Return
Channel 1
ADC Channel number
Channel 2
Switch 1
On Value
Off Value
Switch 2
On Value
Off Value
GetTouchValue
- BOOL Switch
GetTouchPressed
- BOOL Switch
- UINT OffValue
- BYTE Threshold
- BOOL Return
Channel 1
ADC Channel number
Channel 2
Switch 1
On Value
Off Value
Switch 2
On Value
Off Value
GetTouchValue
- BOOL Switch
GetTouchPressed
- BOOL Switch
- UINT OffValue
- BYTE Threshold
- BOOL Return
Channel 1
ADC Channel number
Channel 2
Switch 1
On Value
Off Value
Switch 2
On Value
Off Value
