Component: Humidity (EBM016) (EBM Modules)
Revision as of 09:56, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category EBM Modules
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here to download the component source project: FC_Comp_Source_EBM016v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM016v1.fcfx
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
EBM016 Example
GetTemperatureReal
Return temperature reading as a float value in degrees C
- FLOAT Return
GetTemperatureData
Returns the raw register pair value
GetTemperatureInt
Return temperature reading as an integer value in degrees C
- INT Return
GetHumidityInt
returns the relative Humidity reading as an integer value
- INT Return
GetHumidityReal
returns the Humidity reading as a float value
- FLOAT Return
GetHumidityData
Initialises the component ready for I2C communications
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulation Comms
GetTemperatureReal
- FLOAT Return
GetTemperatureData
GetTemperatureInt
- INT Return
GetHumidityInt
- INT Return
GetHumidityReal
- FLOAT Return
GetHumidityData
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulation Comms
GetTemperatureReal
- FLOAT Return
GetTemperatureData
GetTemperatureInt
- INT Return
GetHumidityInt
- INT Return
GetHumidityReal
- FLOAT Return
GetHumidityData
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulation Comms
GetTemperatureReal
- FLOAT Return
GetTemperatureData
GetTemperatureInt
- INT Return
GetHumidityInt
- INT Return
GetHumidityReal
- FLOAT Return
GetHumidityData
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulation Comms
