| Author
Matrix TSL
| Version
1.0
| Category
E-blocks 2
Actuators component
The Actuators board allows for investigation into several different motor types.  Included on the board is a DC motor with both analogue and digital feedback,  a servo motor and a stepper motor plus the circuitry to drive the motors.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Actuators_BL0127.fcfx
Sample program using the EBM020 - Infrared sensor.
Transmits a signal and determines distance from reflected value
EBM020 Example
DCMotor_DC_Feedback
  - BYTE
DCMotor_Reverse
| Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
  - UINT
Duty
| Sets the motor power for PWM or H-Bridge outputs
Servo_MoveToPosition
| Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called.  Returns 1 if the position has been reached.
  - BYTE
| The channel to assign the new position. Range: 0-7
  - BYTE
Position
| Target position to move towards. Range: 0-255
  - BYTE
DCMotor_Enable
| Enables the motor output
Stepper_DisableMotor
| Turn off the motor.  It will no longer respond to any other macros.
Stepper_IncrementStep
| Move the motor forward by one step.
Servo_EnableServo
| Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
  - BYTE
| The channel to set the position for.  First channel is zero.
Servo_SetAutoMoveSpeed
| Sets the speed of the auto move to position macro.  Default speed is shown in the Servo_Period_Multiplier property.
  - BYTE
Speed
| 1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
Servo_MoveToPositionInt
  - BYTE
  - UINT
Position
| Target position to move towards. Range: 0-65535
  - BYTE
DCMotor_Coast
| Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Servo_IsAutoMoving
| Is the AutoMoveToPosition movement complete.   Returns 1 if the servos are still moving.  Returns 0 if all servo movement is complete.
  - BYTE
Servo_IsServoAutoMoving
| Is the AutoMoveToPosition movement complete for a specific servo output.  Returns 1 if the servo is still moving.   Returns 0 if the servo movement is complete.
  - BYTE
| Servo Motor Output Range: 0-7
  - BYTE
Stepper_DecrementStep
| Move the motor backwards by one step.
Servo_SetPositionInt
| Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
  - BYTE
  - UINT
Position
| Position to jump to. Range: 0-65535
Servo_SetTrim
| Allows the level of trim for each servo channel to be adjusted progmatically.
  - BYTE
  - BYTE
Trim
| Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
DCMotor_Break
| Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Servo_Initialise
| Sets up the servo motor interrupts
DCMotor_Forwards
| Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
  - UINT
Duty
Servo_SetAutoMoveSpeedInt
  - UINT
Speed
DCMotor_Disable
| Disable the motor output
Stepper_EnableMotor
| Turn on the motor.  This must be done before it will respond to any other macros.
Servo_SetPosition
  - BYTE
  - BYTE
Position
| Position to jump to. Range: 0-255
DCMotor_DC_FeedbackSim
  - BYTE
Servo_AutoMoveToPosition
| Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
  - BYTE
  - BYTE
Position
| Position to automatically move to. Range: 0-255
Servo_AutoMoveToPositionInt
| Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
  - BYTE
  - UINT
Position
| Position to automatically move to. Range: 0-65535
Servo_DisableServo
| Disables a servo channel effectivly disabling the motor.
  - BYTE
Connection Type
DC Feedback type
| Select if the feedback is a digital or analogue value. Note, if using an Arduino shield and port D is selected, then only digital type will be available.
Port
| Port C is not available on the Arduino shield, If port C is slected, it will default to port B.
Servo
Trim
Pulse Width
Minimum (us)
| Shortest pulse width that will be used in microseconds.
Maximum (us)
| Longest pulse width used for the PWM signals  in microseconds..
Period Multiplier
| Number of instructions for 1 / 256th of the positional accuracy. This sets the default movement speed to maintain legacy move speeds. Also sets the multiplication factor to convert from a byte 0-255 to a clocked position value.
DCMotor_DC_Feedback
  - BYTE
DCMotor_Reverse
  - UINT
Duty
  - BYTE
  - BYTE
Position
  - BYTE
DCMotor_Enable
Servo_EnableServo
  - BYTE
  - BYTE
Speed
  - BYTE
  - UINT
Position
  - BYTE
DCMotor_Coast
Servo_IsAutoMoving
  - BYTE
  - BYTE
  - BYTE
  - BYTE
  - UINT
Position
Servo_SetTrim
  - BYTE
  - BYTE
Trim
DCMotor_Break
Servo_Initialise
DCMotor_Forwards
  - UINT
Duty
  - UINT
Speed
DCMotor_Disable
Stepper_EnableMotor
Servo_SetPosition
  - BYTE
  - BYTE
Position
  - BYTE
  - BYTE
  - BYTE
Position
  - BYTE
  - UINT
Position
Servo_DisableServo
  - BYTE
Connection Type
DC Feedback type
Port
Servo
Trim
Pulse Width
Minimum (us)
Maximum (us)
Period Multiplier
DCMotor_DC_Feedback
  - BYTE
DCMotor_Reverse
  - UINT
Duty
  - BYTE
  - BYTE
Position
  - BYTE
DCMotor_Enable
Servo_EnableServo
  - BYTE
  - BYTE
Speed
  - BYTE
  - UINT
Position
  - BYTE
DCMotor_Coast
Servo_IsAutoMoving
  - BYTE
  - BYTE
  - BYTE
  - BYTE
  - UINT
Position
Servo_SetTrim
  - BYTE
  - BYTE
Trim
DCMotor_Break
Servo_Initialise
DCMotor_Forwards
  - UINT
Duty
  - UINT
Speed
DCMotor_Disable
Stepper_EnableMotor
Servo_SetPosition
  - BYTE
  - BYTE
Position
  - BYTE
  - BYTE
  - BYTE
Position
  - BYTE
  - UINT
Position
Servo_DisableServo
  - BYTE
Connection Type
DC Feedback type
Port
Servo
Trim
Pulse Width
Minimum (us)
Maximum (us)
Period Multiplier
DCMotor_DC_Feedback
  - BYTE
DCMotor_Reverse
  - UINT
Duty
  - BYTE
  - BYTE
Position
  - BYTE
DCMotor_Enable
Servo_EnableServo
  - BYTE
  - BYTE
Speed
  - BYTE
  - UINT
Position
  - BYTE
DCMotor_Coast
Servo_IsAutoMoving
  - BYTE
  - BYTE
  - BYTE
  - BYTE
  - UINT
Position
Servo_SetTrim
  - BYTE
  - BYTE
Trim
DCMotor_Break
Servo_Initialise
DCMotor_Forwards
  - UINT
Duty
  - UINT
Speed
DCMotor_Disable
Stepper_EnableMotor
Servo_SetPosition
  - BYTE
  - BYTE
Position
  - BYTE
  - BYTE
  - BYTE
Position
  - BYTE
  - UINT
Position
Servo_DisableServo
  - BYTE
Connection Type
DC Feedback type
Port
Servo
Trim
Pulse Width
Minimum (us)
Maximum (us)
Period Multiplier
