Author
Version
1.0
Category
E-blocks 2
CAN_Bus_BL0140 component
Please click here to download the component source project: FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
ReadSwitches
Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only)
- BYTE
SetTxData
Assigns one of the outgoing transmit buffers with data ready to be sent.
- BYTE
Buffer
- BYTE
Count
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
SetRxMask
Allows the receive ID mask to be configured on the fly allowing different ID ranges to be received.
- BYTE
Mask
Specifies which receive mask to modify. Range: 0-1
- ULONG
ID
The ID mask value you wish to use
GetRxData
Returns last received message data byte at position Index. Buffer parameter is currently ignored
- BYTE
Buffer
- BYTE
Index
- BYTE
GetRxIDHi
Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE
Buffer
Receive Buffer. Range 0-1
- BYTE
SetTxIDSimple
Set the Tx CAN ID as a generic number. Standard IDs only 0-2047.
- BYTE
Buffer
Transmit buffer to load. Range: 0-2
- UINT
ID
The ID value you wish to use. Range: 0-2047
SendBuffer
Transmits one of the transmit buffers which should have already been populated with an ID and data.
- BYTE
Buffer
Specifies which transmit buffer to send
GetRxDataCount
Returns last received message data length. Buffer parameter is currently ignored
- BYTE
Buffer
- BYTE
SetRxFilterID
sets the Filter Standard mode only (for V5 compatibility only)
- BYTE
Filter
Specifies which filter to modify. Range: 0-5
- BYTE
ID bits 3-10
- BYTE
Lo
ID bits 0-2 stored in the upper 3 bits of the byte
GetRxIDLo
Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE
Buffer
- BYTE
SetRxFilter
Allows the receive ID filter to be configured on the fly allowing different ID ranges to be received.
- BYTE
Filter
Specifies which receive filter to modify. Range: 0-5
- ULONG
ID
The ID filter value you wish to use
SetRxMaskID
set the Mask Standard ID mode only (for V5 compatibility)
- BYTE
Mask
- BYTE
ID bits 3-10
- BYTE
Lo
SetTxIdent
Set the Tx CAN ID as a generic number. Standard and extended IDs Standard 0-2047 Extended 2048-536870911
- BYTE
Buffer
- ULONG
ID
The ID or Extended ID value you wish to use. Range: 0-536870911
CheckRx
Checks to see if any messages are available for 'Buffer' specified
- BYTE
Buffer
Send buffer: 0 to 1
- BYTE
ChangeRate
Simple attempt to alter the bus rate of the CAN. External CAN channels only,
- BYTE
Rate
Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000
GetRxIDSimple
Gets the Rx ID as a Integer Standard ID only 0-2047.
- BYTE
Buffer
- UINT
SetTxID
Set the Tx CAN ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE
Buffer
- BYTE
ID bits 3-10 e.g. ((ID & 0x7F8) >> 3)
- BYTE
Lo
ID bits 0-2 stored in the upper 3 bits of the byte e.g. ((ID & 0x7) << 5)
GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
- BYTE
Buffer
- ULONG
ShowLEDs
Set LED state (External CAN only)
- BYTE
led1
Controls LED 1. Range: 0-1
- BYTE
led2
Controls LED 2. Range: 0-1
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
SPI
External/Internal
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
CHANNEL
SPI Channel selector
Port
INT
CS (SS)
MOSI
MISO
CLK
Prescale
Prescale option selector
Sample Point
Data bit read sample point
Config Delay
TX Buffer 0
Message ID
TX Buffer 0 Message Identifier
Length
TX Buffer 0 Number of data bytes
D0
TX Buffer 0 Data Byte 0
D1
TX Buffer 0 Data Byte 1
D2
TX Buffer 0 Data Byte 2
D3
TX Buffer 0 Data Byte 3
D4
TX Buffer 0 Data Byte 4
D5
TX Buffer 0 Data Byte 5
D6
TX Buffer 0 Data Byte 6
D7
TX Buffer 0 Data Byte 7
TX Buffer 1
Message ID
TX Buffer 1 Message Identifier
Length
TX Buffer 1 Number of data bytes
D0
TX Buffer 1 Data Byte 0
D1
TX Buffer 1 Data Byte 1
D2
TX Buffer 1 Data Byte 2
D3
TX Buffer 1 Data Byte 3
D4
TX Buffer 1 Data Byte 4
D5
TX Buffer 1 Data Byte 5
D6
TX Buffer 1 Data Byte 6
D7
TX Buffer 1 Data Byte 7
TX Buffer 2
Message ID
TX Buffer 2 Message Identifier
Length
TX Buffer 2 Number of data bytes
D0
TX Buffer 2 Data Byte 0
D1
TX Buffer 2 Data Byte 1
D2
TX Buffer 2 Data Byte 2
D3
TX Buffer 2 Data Byte 3
D4
TX Buffer 2 Data Byte 4
D5
TX Buffer 2 Data Byte 5
D6
TX Buffer 2 Data Byte 6
D7
TX Buffer 2 Data Byte 7
RX Buffer 0
Settings
RX Buffer 0 Message Receive Mode
RX Buffer 1
Settings
RX Buffer 1 Message Receive Mode
Simulate SPI Comms
ReadSwitches
- BYTE
SetTxData
- BYTE
Buffer
- BYTE
Count
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
SetRxMask
- BYTE
Mask
- ULONG
ID
GetRxData
- BYTE
Buffer
- BYTE
Index
- BYTE
GetRxIDHi
- BYTE
Buffer
- BYTE
SetTxIDSimple
- BYTE
Buffer
- UINT
ID
SendBuffer
- BYTE
Buffer
GetRxDataCount
- BYTE
Buffer
- BYTE
SetRxFilterID
- BYTE
Filter
- BYTE
ID bits 3-10
- BYTE
Lo
GetRxIDLo
- BYTE
Buffer
- BYTE
SetRxFilter
- BYTE
Filter
- ULONG
ID
SetRxMaskID
- BYTE
Mask
- BYTE
ID bits 3-10
- BYTE
Lo
SetTxIdent
- BYTE
Buffer
- ULONG
ID
CheckRx
- BYTE
Buffer
Send buffer: 0 to 1
- BYTE
ChangeRate
- BYTE
Rate
GetRxIDSimple
- BYTE
Buffer
- UINT
SetTxID
- BYTE
Buffer
- BYTE
- BYTE
Lo
GetRxIdent
- BYTE
Buffer
- ULONG
ShowLEDs
- BYTE
led1
- BYTE
led2
SPI
External/Internal
CHANNEL
Port
INT
CS (SS)
MOSI
MISO
CLK
Prescale
Sample Point
Config Delay
TX Buffer 0
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 1
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 2
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
RX Buffer 0
Settings
RX Buffer 1
Settings
Simulate SPI Comms
ReadSwitches
- BYTE
SetTxData
- BYTE
Buffer
- BYTE
Count
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
SetRxMask
- BYTE
Mask
- ULONG
ID
GetRxData
- BYTE
Buffer
- BYTE
Index
- BYTE
GetRxIDHi
- BYTE
Buffer
- BYTE
SetTxIDSimple
- BYTE
Buffer
- UINT
ID
SendBuffer
- BYTE
Buffer
GetRxDataCount
- BYTE
Buffer
- BYTE
SetRxFilterID
- BYTE
Filter
- BYTE
ID bits 3-10
- BYTE
Lo
GetRxIDLo
- BYTE
Buffer
- BYTE
SetRxFilter
- BYTE
Filter
- ULONG
ID
SetRxMaskID
- BYTE
Mask
- BYTE
ID bits 3-10
- BYTE
Lo
SetTxIdent
- BYTE
Buffer
- ULONG
ID
CheckRx
- BYTE
Buffer
Send buffer: 0 to 1
- BYTE
ChangeRate
- BYTE
Rate
GetRxIDSimple
- BYTE
Buffer
- UINT
SetTxID
- BYTE
Buffer
- BYTE
- BYTE
Lo
GetRxIdent
- BYTE
Buffer
- ULONG
ShowLEDs
- BYTE
led1
- BYTE
led2
SPI
External/Internal
CHANNEL
Port
INT
CS (SS)
MOSI
MISO
CLK
Prescale
Sample Point
Config Delay
TX Buffer 0
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 1
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 2
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
RX Buffer 0
Settings
RX Buffer 1
Settings
Simulate SPI Comms
ReadSwitches
- BYTE
SetTxData
- BYTE
Buffer
- BYTE
Count
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
SetRxMask
- BYTE
Mask
- ULONG
ID
GetRxData
- BYTE
Buffer
- BYTE
Index
- BYTE
GetRxIDHi
- BYTE
Buffer
- BYTE
SetTxIDSimple
- BYTE
Buffer
- UINT
ID
SendBuffer
- BYTE
Buffer
GetRxDataCount
- BYTE
Buffer
- BYTE
SetRxFilterID
- BYTE
Filter
- BYTE
ID bits 3-10
- BYTE
Lo
GetRxIDLo
- BYTE
Buffer
- BYTE
SetRxFilter
- BYTE
Filter
- ULONG
ID
SetRxMaskID
- BYTE
Mask
- BYTE
ID bits 3-10
- BYTE
Lo
SetTxIdent
- BYTE
Buffer
- ULONG
ID
CheckRx
- BYTE
Buffer
Send buffer: 0 to 1
- BYTE
ChangeRate
- BYTE
Rate
GetRxIDSimple
- BYTE
Buffer
- UINT
SetTxID
- BYTE
Buffer
- BYTE
- BYTE
Lo
GetRxIdent
- BYTE
Buffer
- ULONG
ShowLEDs
- BYTE
led1
- BYTE
led2
SPI
External/Internal
CHANNEL
Port
INT
CS (SS)
MOSI
MISO
CLK
Prescale
Sample Point
Config Delay
TX Buffer 0
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 1
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
TX Buffer 2
Message ID
Length
D0
D1
D2
D3
D4
D5
D6
D7
RX Buffer 0
Settings
RX Buffer 1
Settings
Simulate SPI Comms
