Component: Keypad (BL0138) (BL0138) (E-blocks 2)
Revision as of 09:56, 27 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Keypad (BL0138) component
Keypad component to drive the E-blocks 2 BL0138 Keypad board. Provides twelve individual raster scanned switches.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_KeyPad_BL0138.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_KeyPad_BL0138.fcfx
Fc9-comp-macro.png WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
Fc9-comp-macro.png GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
Fc9-comp-macro.png GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
Fc9-comp-macro.png GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
Fc9-comp-macro.png GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
Fc9-comp-macro.png WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Fc9-type-16-icon.png Port
From here, set the port to which your EB014 is connected. If you are wiring your own hardware, you can use the 'Custom Pins' setting to allow the selection of individual pins for each row or column.
