Component: Quadrature Encoder 2D (General Input)
Version | 1.4 |
Category | General Input |
Quadrature Encoder 2D component
Quadrature Encoder component implements a rotary encoder connected to two pins. Quadrature Encoders provides incremental positioning rather than absolute positioning.
Please click here to download the component source project: FC_Comp_Source_Encoder_Quadrature_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Encoder_Quadrature_2dgi.fcfx
CheckForChanges |
Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error | |
Return |
Disable |
Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
Return |
WriteCounter32 |
Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
Value |
Return |
Enable |
Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
Return |
ReadCounter |
Reads the current dial counter This is a counter from -32768 to 32767 | |
Return |
WriteCounter |
Sets the value of the internal count variable. Range: -32768 to 32767 | |
Value |
Return |
ResetCounter |
Resets the current dial counter to zero | |
Return |
ReadCounter32 |
Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
Return |
CheckForChanges |
Return |
Disable |
Return |
WriteCounter32 |
Value |
Return |
Enable |
Return |
ReadCounter |
Return |
WriteCounter |
Value |
Return |
ResetCounter |
Return |
ReadCounter32 |
Return |
CheckForChanges |
Return |
Disable |
Return |
WriteCounter32 |
Value |
Return |
Enable |
Return |
ReadCounter |
Return |
WriteCounter |
Value |
Return |
ResetCounter |
Return |
ReadCounter32 |
Return |
CheckForChanges |
Return |
Disable |
Return |
WriteCounter32 |
Value |
Return |
Enable |
Return |
ReadCounter |
Return |
WriteCounter |
Value |
Return |
ResetCounter |
Return |
ReadCounter32 |
Return |
