Component: GLCD (SSD1327) I2C (SSD1327) (Graphical Monochrome)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.9
Category Graphical Monochrome
GLCD (SSD1327) I2C component
Graphical display component based on the I2C version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1327_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1327_I2C.fcfx
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-comp-macro.png Refresh
Refreshes the entire display by sending the contents of the local RAM to the display at high speed
Fc9-comp-macro.png SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
Fc9-u8-icon.png - BYTE Shade
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png InvertDisplay
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Flip
Determines if the display is flipped or not
Fc9-type-7-icon.png Auto Draw
Yes: Default - Lines, Text, Clear will all be done automatically No: Data will be sent only to the internal RAM, the display will be updated using the Refresh command
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png I2C Address
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Physical Orientation
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Fc9-conn-icon.png Communications
Fc9-type-16-icon.png API
0=Off, 1=On
0=White, 1=Black
0=White, 1=Black
Channel selection
0=Off, 1=On
0=White, 1=Black
0=White, 1=Black
Channel selection
0=Off, 1=On
0=White, 1=Black
0=White, 1=Black
Channel selection
