Component: GSM (EB066, Generic AT) (Wireless)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Wireless
GSM (EB066, Generic AT) component
Low level routines for controlling a standard AT GSM / GPRS interface Also available in the form of the EB066 GSM E-block.
Please click here to download the component source project: FC_Comp_Source_GSM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GSM.fcfx
DialNumber
Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response.
- STRING Number
GetTextString
Collects the text message data from an incoming text message.
- BYTE NumBytes
- STRING Return
SendString
Sends a string to the GSM module.
- STRING Text
SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
- BYTE idx
SendCommand
Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply
- STRING Command
- BYTE SendCR
AnswerIncomingCall
Answers the phone for an incoming type call. Returns 0 for success and 255 for failure.
GetTextNumber
Collects the sender's phone number from an incoming text message.
- BYTE NumBytes
- STRING Return
HangUpCall
Ends a voice based call. Returns 0 for success and 255 for failure.
ReadString
Copies the data from the data string array to a local string variable
- BYTE NumBytes
- STRING Return
SendTextMessage
Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure.
- STRING Number
- STRING Message
StringReceive
Attempts to receive a string from the GSM modem.
DeleteAllMessages
Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail.
CheckNetworkStatus
Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM.
CheckForIncoming
Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Expect Echo
Sets if we expect an echo of any data we send out to the GSM modem. Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
String Array Size
Amount of RAM memory to dedicate to receiving responces from the GSM
Message Array Size
Amount of RAM memory to dedicate to storing the last SMS message received by the GSM.
Script Count
Maximum number of scripts to store in the device's ROM
Script1
ASCII based AT command data stored in ROM and used when sending script 1
TX
RX
Use Flow Control
Baud Options
Textual label shown on the component I/O flasher
Console Columns
Data Source
DialNumber
- STRING Number
GetTextString
- BYTE NumBytes
- STRING Return
SendString
- STRING Text
SendScript
- BYTE idx
SendCommand
- STRING Command
- BYTE SendCR
AnswerIncomingCall
GetTextNumber
- BYTE NumBytes
- STRING Return
HangUpCall
ReadString
- BYTE NumBytes
- STRING Return
SendTextMessage
- STRING Number
- STRING Message
StringReceive
DeleteAllMessages
CheckNetworkStatus
CheckForIncoming
Expect Echo
String Array Size
Message Array Size
Script Count
Script1
TX
RX
Use Flow Control
Baud Options
Console Columns
Data Source
DialNumber
- STRING Number
GetTextString
- BYTE NumBytes
- STRING Return
SendString
- STRING Text
SendScript
- BYTE idx
SendCommand
- STRING Command
- BYTE SendCR
AnswerIncomingCall
GetTextNumber
- BYTE NumBytes
- STRING Return
HangUpCall
ReadString
- BYTE NumBytes
- STRING Return
SendTextMessage
- STRING Number
- STRING Message
StringReceive
DeleteAllMessages
CheckNetworkStatus
CheckForIncoming
Expect Echo
String Array Size
Message Array Size
Script Count
Script1
TX
RX
Use Flow Control
Baud Options
Console Columns
Data Source
DialNumber
- STRING Number
GetTextString
- BYTE NumBytes
- STRING Return
SendString
- STRING Text
SendScript
- BYTE idx
SendCommand
- STRING Command
- BYTE SendCR
AnswerIncomingCall
GetTextNumber
- BYTE NumBytes
- STRING Return
HangUpCall
ReadString
- BYTE NumBytes
- STRING Return
SendTextMessage
- STRING Number
- STRING Message
StringReceive
DeleteAllMessages
CheckNetworkStatus
CheckForIncoming
Expect Echo
String Array Size
Message Array Size
Script Count
Script1
TX
RX
Use Flow Control
Baud Options
Console Columns
Data Source
