Component: GameCode (Misc Circuit)
| Author | Jef De Bruyne |
| Category | Misc Circuit |
GameCode component
A small handheld device designed for creating embedded games. Complete with a 8 x 16 LED display, 4-Way DPAD with 4 additional push switches Buzzer, Vibration, MP3 Player, Potentiometer and Lithium battery management. Programmed via USB.
Please click here to download the component source project: FC_Comp_Source_GameCode_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GameCode_Master.fcfx
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
| PwrLedSet | |
| Control the PWR LED. 0 = red + green 1 = red 2 = green | |
| Value | |
| 0 = red + green, 1 = red, 2 = green | |
| EEStoreValue | |
| Saves a value to none volitile memory | |
| Address | |
| Address to write to, Range: 0-255 | |
| Value | |
| Value to store, Range: 0-255 | |
| MP3GetStatus | |
| Returns the status of the MP3 module. 0 = module in sleep 1 = track is playing 2 = track is pauzed 3 = track is stopped | |
| MP3PausePlayResetStop | |
| Allows the current playing track to be paused, restarted or stopped. | |
| Mode | |
| 0=Pause, 1=Play, 2=Reset, 3=Stop | |
| MP3SendCommand | |
| Send commands to MP3 module. Check datasheet for info. | |
| Command | |
| Para1 | |
| Para2 | |
| EEReadValue | |
| Retreives a value from none volitile memory | |
| Address | |
| DisplayWriteNumber | |
| Show a number ranging from 000 to 999 on the display. Number is printed vertically. | |
| Value | |
| Enter a number from 0 to 999. | |
| DisplayClear | |
| Clear the display. | |
| BatteryRead | |
| Read and return the voltage level of the battery in millivolt. | |
| LedsWrite | |
| Set the button-leds. MSB = leftmost led LSB = rightmost led | |
| Value | |
| MSB = leftmost dot, LSB = rightmost dot | |
| MP3SetVolume | |
| Sets the volume level for the MP3 module | |
| Volume | |
| Range: 0 (min) - 30 (max) | |
| DisplayBrightness | |
| Control the brightness of the display. | |
| Value | |
| Enter value from 0 to 15 | |
| Initializes all present hardware and communication. Place this at the very start of your code. | |
| Properties | |
| LED Colours | |
| LED On | |
| LED Off | |
| Display Colours | |
| On Colour | |
| Off Colour | |
| Background Colour | |
| PwrLedSet | |
| Value | |
| EEStoreValue | |
| Address | |
| Value | |
| MP3GetStatus | |
| Mode | |
| MP3SendCommand | |
| Command | |
| Para1 | |
| Para2 | |
| EEReadValue | |
| Address | |
| Value | |
| DisplayClear | |
| BatteryRead | |
| LedsWrite | |
| Value | |
| MP3SetVolume | |
| Volume | |
| Value | |
| Properties | |
| LED Colours | |
| LED On | |
| LED Off | |
| Display Colours | |
| On Colour | |
| Off Colour | |
| PwrLedSet | |
| Value | |
| EEStoreValue | |
| Address | |
| Value | |
| MP3GetStatus | |
| Mode | |
| MP3SendCommand | |
| Command | |
| Para1 | |
| Para2 | |
| EEReadValue | |
| Address | |
| Value | |
| DisplayClear | |
| BatteryRead | |
| LedsWrite | |
| Value | |
| MP3SetVolume | |
| Volume | |
| Value | |
| Properties | |
| LED Colours | |
| LED On | |
| LED Off | |
| Display Colours | |
| On Colour | |
| Off Colour | |
| PwrLedSet | |
| Value | |
| EEStoreValue | |
| Address | |
| Value | |
| MP3GetStatus | |
| Mode | |
| MP3SendCommand | |
| Command | |
| Para1 | |
| Para2 | |
| EEReadValue | |
| Address | |
| Value | |
| DisplayClear | |
| BatteryRead | |
| LedsWrite | |
| Value | |
| MP3SetVolume | |
| Volume | |
| Value | |
| Properties | |
| LED Colours | |
| LED On | |
| LED Off | |
| Display Colours | |
| On Colour | |
| Off Colour | |
