Component: HBRIDGE (CAL) (Misc)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.1
Category Misc
HBRIDGE component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the H-Bridge peripheral. Currently only supports compatible 8-bit PIC devices.
Please click here to download the component source project: FC_Comp_Source_HBRIDGE.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_HBRIDGE.fcfx
Half Bridge Application
A Half Bridge type output has two output signals A and B.
Full Bridge Application
Full Bridge type output has four output signals A, B, C and D.
A simple proof of concept example to drive a full bridge output with varying speed and direction.
PIC16F1937 H-Bridge Example
PIC16F18877 H-Bridge Example
GetValue
Returns Named property Value
- STRING Name
- STRING Return
Disable
Disable this PWM Channel
Enable
Enable this PWM Channel
SetSpeed
Sets the motor speed by varying the PWM duty.
- UINT duty
Duty value 0 - 1023
SetValue
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
- STRING Name
- STRING Value
SetDirection
Set the motor direction.
- BYTE direction
0 = Forwards, 1 = Reverse
GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
- STRING Name
- STRING Return
Enable
Settings
PWM Channel selector
Mode
Selects between full bridge and half bridge output modes. Some H-Bridge channels may only have one mode in which case the property selector will only show the available mode.
Polarity
Selects the active output voltage. Active high - Pins will be low when inactive and high when active. Active Low- Pins will be high when inactive and low when active.
Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Prescaler Divide
Prescaler Divider value
Period Register
PWM Period Register value
Dead Band
Rising Bits
Number of bits assigned to the rising edge dead band counter. Auto populated based on selected target chip.
Falling Bits
Number of bits assigned to the falling edge dead band counter. Auto populated based on selected target chip.
Rising Count
Number of cycles to wait after a falling edge and before a rising edge.
Falling Count
Number of cycles to wait after a rising edge and before a falling edge.
A Pin
Output Pin A
B Pin
Output Pin B
C Pin
Output Pin C
D Pin
Output Pin D
A Remap Pin
Remap Pin A - Specifies the pin used for the A output. Only available on devices supporting remappable hardware pins.
B Remap Pin
Remap Pin B - Specifies the pin used for the B output. Only available on devices supporting remappable hardware pins.
C Remap Pin
Remap Pin C - Specifies the pin used for the C output. Only available on devices supporting remappable hardware pins.
D Remap Pin
Remap Pin D - Specifies the pin used for the D output. Only available on devices supporting remappable hardware pins.
Calculations
Clock Speed
Target Microcontroller Clock Speed.
Period (uS)
Calculated length of PWM period in micro seconds.
Frequency (KHz)
Calculated PWM output frequency in KHz.
Frequency (Hz)
Calculated PWM output frequency in Hz.
GetValue
- STRING Name
- STRING Return
Disable
Enable
SetSpeed
- UINT duty
Duty value 0 - 1023
SetValue
- STRING Name
- STRING Value
SetDirection
- BYTE direction
GetList
- STRING Name
- STRING Return
Enable
Settings
Mode
Polarity
Timer
Prescaler Divide
Period Register
Dead Band
Rising Bits
Falling Bits
Rising Count
Falling Count
A Pin
Output Pin A
B Pin
Output Pin B
C Pin
Output Pin C
D Pin
Output Pin D
A Remap Pin
B Remap Pin
C Remap Pin
D Remap Pin
Calculations
Clock Speed
Period (uS)
Frequency (KHz)
Frequency (Hz)
GetValue
- STRING Name
- STRING Return
Disable
Enable
SetSpeed
- UINT duty
Duty value 0 - 1023
SetValue
- STRING Name
- STRING Value
SetDirection
- BYTE direction
GetList
- STRING Name
- STRING Return
Enable
Settings
Mode
Polarity
Timer
Prescaler Divide
Period Register
Dead Band
Rising Bits
Falling Bits
Rising Count
Falling Count
A Pin
Output Pin A
B Pin
Output Pin B
C Pin
Output Pin C
D Pin
Output Pin D
A Remap Pin
B Remap Pin
C Remap Pin
D Remap Pin
Calculations
Clock Speed
Period (uS)
Frequency (KHz)
Frequency (Hz)
GetValue
- STRING Name
- STRING Return
Disable
Enable
SetSpeed
- UINT duty
Duty value 0 - 1023
SetValue
- STRING Name
- STRING Value
SetDirection
- BYTE direction
GetList
- STRING Name
- STRING Return
Enable
Settings
Mode
Polarity
Timer
Prescaler Divide
Period Register
Dead Band
Rising Bits
Falling Bits
Rising Count
Falling Count
A Pin
Output Pin A
B Pin
Output Pin B
C Pin
Output Pin C
D Pin
Output Pin D
A Remap Pin
B Remap Pin
C Remap Pin
D Remap Pin
Calculations
Clock Speed
Period (uS)
Frequency (KHz)
Frequency (Hz)
