Component: Temp / Humidity (HTS221) (Environmental)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Category Environmental
Temp / Humidity (HTS221) component
A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 3.5% Temperature Range = -40 - 120 Degrees C +/- 0.5 Degrees C
Please click here to download the component source project: FC_Comp_Source_Humidity_HTS221.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_HTS221.fcfx
Fc9-comp-macro.png ReadHumidityInt
Samples the humidity from the sensor and returns the relative humidity reading as a integer byte from 0 to 100
Fc9-comp-macro.png DataAvailable
Checks to see if new sensor data is available. Returns 0 if no new data is available. Returns 1 if new Temperature data is available. Returns 2 if new Humidity data is available. Returns 3 if new Temp and Humidity data is available.
Fc9-comp-macro.png ReadTemperatureInt
Samples the temperature from the sensor and returns the reading in degrees C as an integer from -40 to 120.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ControlHeater
Controls the in-built heater element to speed up sensor recovery time in case of condensation. Humidity and temperature cannot be read while Heater is active.
Fc9-bool-icon.png - BOOL Active
0 = Off (Sensor Reading Available) / 1 = On (Sensor Reading Disabled)
Fc9-comp-macro.png ReadHumidityReal
Samples the humidity from the sensor and returns the relative humidity reading as a float from 0.0 to 100.0.
Fc9-comp-macro.png ReadRegister
Reads an 8-bit value from one of the registers onboard the sensor IC.
Fc9-comp-macro.png ReadTemperatureReal
Samples the temperature from the sensor and returns the reading in degrees C as a float from -40.0 to 120.0.
Fc9-comp-macro.png WriteRegister
Writes a value to a register on the sensor IC.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Configures the I2C peripheral ready for communications.
Fc9-conn-icon.png Sensor Properties
Fc9-type-16-icon.png Data Rate
Fc9-conn-icon.png I2C Properties
Fc9-type-14-icon.png Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Sim Type
Channel selection
Channel selection
Channel selection
