| Author
Matrix TSL
| Version
2.0
| Category
Comms: Interface
I2S Master/Slave ESP32 component
Provides access to the onboard inter-IC sound (I2S) peripheras allowing for simple digital audio input and output.
Please click here to download the component source project: FC_Comp_Source_I2S.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_I2S.fcfx
Stop
| Stops the I2S audio stream
Read
| Wait timeout ticks to receive length number of samples, returns samples received. 24 and 32-bit data must be split into two integer values per sample.
- INT
Data
| Data array to populate with incoming data
- UINT
Length
| Max number of samples to try and receive
- UINT
Timeout
| Max number of ticks to wait for incoming samples
- UINT
CheckQueue
| Checks the I2S Event queue for a DMA Buffer full or empty event. For an output returns true when there is an empty DMA buffer available. For an input return true when there is a full DMA buffer available.
- BOOL
Write
| Wait timeout ticks to send length number of samples, returns samples sent 24 and 32-bit data must be split into two integer values per sample.
- INT
Data
| Data array containing outgoing data
- UINT
Length
| Max number of samples to try and send
- UINT
Timeout
| Max number of ticks to wait for space in the outgoing buffer
- UINT
Start
| Starts the I2S audio stream, auto started by the initialise function.
| Configures the I2C peripheral ready for data.
| DAC Channel number
Clock Pin
| I2S Clock Pin
Serial Data Pin
| I2S Serial Data (SD) Pin
Word Select Pin
| I2S Word Select (WS) Pin
Mode
| Configures if the I2S peripheral is a master or slave on the bus.
Data Direction
| Controls if the I2S data is coming in or out of the microcontroller
Audio Channels
| Number of distinct audio channels in the data stream
Sample Rate
| Audio sample rate in Hz
Data Bits
| Nmber of bits in each audio sample
DMA Buffer Count
| I2S DMA Buffer Count
DMA Buffer Size
| I2S DMA Buffer Size
Stop
Read
- INT
Data
- UINT
Length
- UINT
Timeout
- UINT
CheckQueue
- BOOL
Write
- INT
Data
- UINT
Length
- UINT
Timeout
- UINT
Start
| DAC Channel number
Clock Pin
| I2S Clock Pin
Serial Data Pin
Word Select Pin
Mode
Data Direction
Audio Channels
Sample Rate
Data Bits
DMA Buffer Count
DMA Buffer Size
| I2S DMA Buffer Size
Stop
Read
- INT
Data
- UINT
Length
- UINT
Timeout
- UINT
CheckQueue
- BOOL
Write
- INT
Data
- UINT
Length
- UINT
Timeout
- UINT
Start
| DAC Channel number
Clock Pin
| I2S Clock Pin
Serial Data Pin
Word Select Pin
Mode
Data Direction
Audio Channels
Sample Rate
Data Bits
DMA Buffer Count
DMA Buffer Size
| I2S DMA Buffer Size
Stop
Read
- INT
Data
- UINT
Length
- UINT
Timeout
- UINT
CheckQueue
- BOOL
Write
- INT
Data
- UINT
Length
- UINT
Timeout
- UINT
Start
| DAC Channel number
Clock Pin
| I2S Clock Pin
Serial Data Pin
Word Select Pin
Mode
Data Direction
Audio Channels
Sample Rate
Data Bits
DMA Buffer Count
DMA Buffer Size
| I2S DMA Buffer Size
