Component: Injector (AT) (Test Injectors)
Revision as of 09:57, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Test Injectors
Injector (AT) component
Comms data injector to replicate basic AT command syntax. The component will record each incoming character until the termination character is received. Once this happens the component will respond by echoing back the received data followed by an "OK" reply.
Please click here to download the component source project: FC_Comp_Source_InjectorAT.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorAT.fcfx
GSM Example File FC6 Icon.png GSM Example Example should show the following on the display on the panel and on the hardware.
The AT injector component allows us to simulate the response of the GSM module.
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
Fc9-comp-macro.png UARTCheckRX
Fc9-comp-macro.png UARTInitialise
Fc9-comp-macro.png UARTSend
Fc9-u8-icon.png - BYTE Data
Fc9-conn-icon.png AT Injector Settings
Fc9-type-21-icon.png Circular Buffer Size
Amount of room in the circular buffers before running out of memory. e.g. max command that can be recorded.
Fc9-type-16-icon.png Termination Character
Character that will trigger the AT Injector to automatically switch from recording to repeating.
Fc9-type-7-icon.png Show Console
