Component: LIN Slave (Comms)
Revision as of 09:58, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Comms
LIN Slave component
Low level routines for controlling the LIN bus (1.3 / 2.0) slave interface.
Please click here to download the component source project: FC_Comp_Source_LinSlave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LinSlave.fcfx
Fc9-comp-macro.png PowerDown
Power Down the device
Fc9-comp-macro.png GetState
Returns the state of the device
Fc9-comp-macro.png ListenForMessages
Listens for messages with Timeout and returns the state
Fc9-u8-icon.png - BYTE Timeout
Fc9-u8-icon.png - BYTE ChecksumType
0=Classic, 1=Enhanced
Fc9-comp-macro.png ReadAddress
Returns the Identifier read
Fc9-comp-macro.png ReadDataCount
Return the data count size for Message
Fc9-u8-icon.png - BYTE Message
Returns the message data byte
Message to be read
Fc9-u8-icon.png - BYTE Index
Index of data byte to be returned
Fc9-comp-macro.png SetData
Set the Message data to be automatically sent as part of the ListenForMessages macro.
Message to assign data for Range: 1-8
Fc9-u8-icon.png - BYTE Data1
Data byte value
Fc9-u8-icon.png - BYTE Data2
Data byte value
Fc9-u8-icon.png - BYTE Data3
Data byte value
Fc9-u8-icon.png - BYTE Data4
Data byte value
Fc9-u8-icon.png - BYTE Data5
Data byte value
Fc9-u8-icon.png - BYTE Data6
Data byte value
Fc9-u8-icon.png - BYTE Data7
Data byte value
Fc9-u8-icon.png - BYTE Data8
Data byte value
Fc9-comp-macro.png Initialize
Initialises the device
Fc9-comp-macro.png WakeUp
Wake Up the device
Fc9-type-5-icon.png TX pin
LIN bus data transmit pin
Fc9-type-5-icon.png RX pin
LIN bus data receive pin
Fc9-type-5-icon.png CS pin
LIN bus chip select pin
Fc9-type-5-icon.png FAULT pin
LIN bus fault detection pin
Fc9-type-5-icon.png VREG pin
LIN bus voltage regulation pin
Fc9-type-16-icon.png MESSAGES
Number of messages the firmware is designed to listen for
Fc9-conn-icon.png MESSAGE1
Fc9-type-14-icon.png ID
Message identifier to listen for
Fc9-type-16-icon.png BYTES
Number of bytes to expent in the packet
Fc9-type-16-icon.png TX_RX
Data direction for packet
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
A text label to aid identifying the component.
Fc9-conn-icon.png Timing Adjustments
Fc9-type-21-icon.png Timer Adjust TX
Fc9-type-21-icon.png Timer Adjust RX
Message to be read
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Wake Up the device
Message to be read
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Wake Up the device
Message to be read
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Data byte value
Wake Up the device
