| Author
Matrix Ltd.
| Version
2.1
| Category
Comms: System
Modbus TCP Slave component
Modbus component for creating Modbus compatible slave hardware via Ethernet or WIFI. Ensure TCP/IP or WIFI component is initialised and connected to a network before calling the ModbusSlaveTCP component macros.
Please click here to download the component source project: FC_Comp_Source_ModbusSlaveTCP.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ModbusSlaveTCP.fcfx
ReadHoldingRegister
| Reads the value of a single holding register.
- UINT
Address
| Coil Address
- UINT
SetCoil
| Sets the state of a single digital coil.
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
| Sets the state of a single digital input.
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
| Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT
SlaveAddress
ReadCoils
| Reads the state of a single digital coil. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
| Coil Address Range 0 to (NumCoils - 1)
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
| Sets the state of a single holding register.
- UINT
Address
| Coil Address
- UINT
Value
| Analogue Value range 0 - 65535
ReadAnalogInput
| Reads the value of a single analogue input.
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
| Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
- BYTE
ReadDigitalInputs
| Reads the state of a single digital input. Can pack a max of 8-bits together in a single operation
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
| Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
- BYTE
Index
| Range: 0-3
- UINT
SetAnalogInput
| Sets the state of a single analogue input.
- UINT
Address
| Coil Address
- UINT
Value
| Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
Modbus TCP/IP Properties
LinkTo
Status
| Shows the state of the network comms component to verify everything is configured correctly.
TCP/IP Port
| Port used for network communications Range: 0-65535
Receive Buffer Size
| Maximum number of bytes the receive buffer can hold
Receive Timeout
| Maximum time to wait for reply, in mS
Slave Address
| Address of the slave. Range: 0-255
Maintain Stats
| Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Open and Close Socket
Simulation Properties
| A text label to appear on the Modbus panel object.
Modbus Coils - Single bit values
Starting Address
| Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Digital Inputs - Single bit values
Starting Address
| Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Analog Inputs - 16-bit values
Starting Address
| Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Holding Registers - 16-bit values
Starting Address
| Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
| Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
ReadHoldingRegister
- UINT
Address
| Coil Address
- UINT
SetCoil
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
| Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
- BYTE
Index
| Range: 0-3
- UINT
SetAnalogInput
- UINT
Address
| Coil Address
- UINT
Value
LinkTo
Status
TCP/IP Port
Receive Buffer Size
Receive Timeout
Slave Address
Maintain Stats
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
ReadHoldingRegister
- UINT
Address
| Coil Address
- UINT
SetCoil
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
| Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
- BYTE
Index
| Range: 0-3
- UINT
SetAnalogInput
- UINT
Address
| Coil Address
- UINT
Value
LinkTo
Status
TCP/IP Port
Receive Buffer Size
Receive Timeout
Slave Address
Maintain Stats
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
ReadHoldingRegister
- UINT
Address
| Coil Address
- UINT
SetCoil
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetDigitalInput
- UINT
Address
| Coil Address
- BYTE
State
| 0=off, 1=on
SetSlaveAddress
- UINT
SlaveAddress
ReadCoils
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
SetHoldingRegister
- UINT
Address
| Coil Address
- UINT
Value
ReadAnalogInput
- UINT
Address
| Coil Address
- UINT
CheckForIncoming
- BYTE
ReadDigitalInputs
- UINT
StartAddress
- BYTE
AddressCount
| Range 1-8
- BYTE
GetLastIncoming
- BYTE
Index
| Range: 0-3
- UINT
SetAnalogInput
- UINT
Address
| Coil Address
- UINT
Value
LinkTo
Status
TCP/IP Port
Receive Buffer Size
Receive Timeout
Slave Address
Maintain Stats
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
Starting Address
Number of Addresses
