Component: One Wire (DS2482) (Comms: Interface)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: Interface
One Wire (DS2482) component
A One Wire master transciever controlled using I2C comms. Useful for microcontroller devices where One Wire communications timings are too tight to do reliably.
Please click here to download the component source project: FC_Comp_Source_One_Wire_DS2482_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_One_Wire_DS2482_I2C.fcfx
ReceiveByte
TransmitByte
Transmit a byte to the one wire bus a bit at a time
- BYTE Command
SkipROM
Performs a bus reset and the sends the SkipROM command byte
BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BOOL Return
MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE FamilyCode
- BYTE SerialNumber
ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
GetDeviceCount
GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
- BYTE Device
Device ID - Range: 0 - NumDevices - 1
- BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Max Devices
Controls the maximum number of devices that can be detected during a ScanBus. For each additional device we require 8 bytes to store the ROM ID. Default: 8 = 64 Bytes of RAM
I2C Properties
Device Address
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
ReceiveByte
TransmitByte
- BYTE Command
SkipROM
BusReset
- BOOL Return
MatchROM
- BYTE FamilyCode
- BYTE SerialNumber
ScanBus
GetDeviceCount
GetIDByte
- BYTE Device
- BYTE ByteIndex
Max Devices
I2C Properties
Device Address
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
ReceiveByte
TransmitByte
- BYTE Command
SkipROM
BusReset
- BOOL Return
MatchROM
- BYTE FamilyCode
- BYTE SerialNumber
ScanBus
GetDeviceCount
GetIDByte
- BYTE Device
- BYTE ByteIndex
Max Devices
I2C Properties
Device Address
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
ReceiveByte
TransmitByte
- BYTE Command
SkipROM
BusReset
- BOOL Return
MatchROM
- BYTE FamilyCode
- BYTE SerialNumber
ScanBus
GetDeviceCount
GetIDByte
- BYTE Device
- BYTE ByteIndex
Max Devices
I2C Properties
Device Address
Channel selection
SDA
SCL
Options
Stop Delay
Baud Select
Simulate Comms
