Component: One Wire Dummy (Misc)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.4 |
| Category | Misc |
One Wire Dummy component
Low level routines for controlling or interacting with a standard one wire interface.
Please click here to download the component source project: FC_Comp_Source_One_Wire_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_One_Wire_Dummy.fcfx
|   | ReceiveByte |
| Receives a byte from the one wire bus a bit at a time | |
|  - BYTE | Return |
|   | TransmitByte |
| Transmit a byte to the one wire bus a bit at a time | |
|  - BYTE | Command |
|  - VOID | Return |
|   | SkipROM |
| Performs a bus reset and the sends the SkipROM command byte | |
|  - VOID | Return |
|   | MatchROM |
| Performs a reset followed by the MatchROM code and then the 8-bit ROM code. | |
|  - BYTE | FamilyCode |
|  - BYTE | SerialNumber |
|  - VOID | Return |
|   | ScanBus |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
|  - BYTE | Return |
|   | GetDeviceCount |
| Returns the number of devices found by the last ScanBus operation. | |
|  - BYTE | Return |
|   | Initialise |
| Sets up the 1-Wire output pin ready for communications. | |
|  - VOID | Return |
|   | Properties |
|   | ReceiveByte |
|  - BYTE | Return |
|   | TransmitByte |
|  - BYTE | Command |
|  - VOID | Return |
|   | SkipROM |
|  - VOID | Return |
|   | MatchROM |
|  - VOID | Return |
|   | ScanBus |
|  - BYTE | Return |
|   | GetDeviceCount |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | ReceiveByte |
|  - BYTE | Return |
|   | TransmitByte |
|  - BYTE | Command |
|  - VOID | Return |
|   | SkipROM |
|  - VOID | Return |
|   | MatchROM |
|  - VOID | Return |
|   | ScanBus |
|  - BYTE | Return |
|   | GetDeviceCount |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
|   | ReceiveByte |
|  - BYTE | Return |
|   | TransmitByte |
|  - BYTE | Command |
|  - VOID | Return |
|   | SkipROM |
|  - VOID | Return |
|   | MatchROM |
|  - VOID | Return |
|   | ScanBus |
|  - BYTE | Return |
|   | GetDeviceCount |
|  - BYTE | Return |
|   | Initialise |
|  - VOID | Return |
|   | Properties |
