Component: Port Matrix (Misc)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Misc
Port Matrix component
Create an accurately spaced array of up to eight components, each corresponding to a pin of the chosen port. If the cloned component has a property called 'pin', this will be set the the corresponding pin of the matrix port, and the component will behave as if it were connected directly to that pin. If there are less than eight clones, the unused upper bits of the port will be masked out to allow them to be used by other components.
Please click here to download the component source project: FC_Comp_Source_Port_Matrix.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Port_Matrix.fcfx
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
Industrial Tanks
BarGraph
Turns on the first N pins of the array - for generating bar graph meters etc.
- BYTE Length
How many pins to enable.
AllOn
Turn on all of the pins in the array (unused port pins are unaffected)
PinOn
Turn on the selected pin of the port.
- BYTE Index
Index of the pin to set within the port.
PinOff
Turn off the chosen pin of the port.
- BYTE Index
PinToggle
Toggles the state of the selected pin of the port.
- BYTE Index
GetPin
Read the state of the selected pin of the port. Returns false if the index is out of range (0..7)
- BYTE Index
Index of the pin to read.
- BOOL Return
GetHandle
Retrieves the object handle of the indexed clone. Returns zero for out of range indexes.
- BYTE Index
Index of the object to get a handle for.
- HANDLE Return
AllOff
Turn off all used pins of the port (unused port pins are unaffected)
Target Object
Choose an object that will be duplicated for each required pin of the chosen port. The object should have a property called 'pin' to which the pins of the port will automatically be attached.
Count
Number of objects in the matrix. They will be assigned pins from the chosen port sequentially, beginning with pin0.
Alignment
Which 3D axis the cloned objects will be arranged along.
Spacing
The distance between cloned objects in the matrix.
Port
Choose a port to connect the matrix of objects to. Each will be assigned a single pin of the port automatically by the Port Matrix component.
BarGraph
- BYTE Length
AllOn
PinOn
- BYTE Index
PinOff
- BYTE Index
PinToggle
- BYTE Index
GetPin
- BYTE Index
- BOOL Return
GetHandle
- BYTE Index
- HANDLE Return
AllOff
Target Object
Count
Alignment
Spacing
Port
BarGraph
- BYTE Length
AllOn
PinOn
- BYTE Index
PinOff
- BYTE Index
PinToggle
- BYTE Index
GetPin
- BYTE Index
- BOOL Return
GetHandle
- BYTE Index
- HANDLE Return
AllOff
Target Object
Count
Alignment
Spacing
Port
BarGraph
- BYTE Length
AllOn
PinOn
- BYTE Index
PinOff
- BYTE Index
PinToggle
- BYTE Index
GetPin
- BYTE Index
- BOOL Return
GetHandle
- BYTE Index
- HANDLE Return
AllOff
Target Object
Count
Alignment
Spacing
Port
