Component: Barometer (MS5637) (Environmental)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Environmental
Barometer (MS5637) component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 0 to 30 Bar. Temperature range -20 to +85 °C.
Please click here to download the component source project: FC_Comp_Source_Pressure_Sensor_MS5637.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_MS5637.fcfx
ReadPressureFloat
Reads the pressure as a floating point value in Bars. Resultion sets the return bit value and conversion time. Calls the ReadPressureRaw function and then converts to a meaningful value.
- BYTE Resolution
Range 0-5
- FLOAT Return
Reset
Resets the device
ReadTemperatureFloat
- BYTE Resolution
Range 0-5
- FLOAT Return
ReadPressureRaw
Reads the pressure as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.11mBar / 1=0.062mBar / 2=0.039mBar 3=0.028mBar / 4=0.021mBar / 5=0.016mBar
- BYTE Resolution
Range 0-5
- ULONG Return
ReadTemperatureRaw
Reads the temperature as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.012°C / 1=0.009°C / 2=0.006°C 3=0.004°C / 4=0.003°C / 5=0.002°C
- BYTE Resolution
Range 0-5
- LONG Return
ReadPROM
Reads a single 16-bit value from the PROM calibration data.
- BYTE Address
Range 0-6
Stes up the I2C bus and initialises the termperature sensor ready for use.
I2C Properties
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
ReadPressureFloat
- BYTE Resolution
Range 0-5
- FLOAT Return
Reset
Resets the device
- BYTE Resolution
Range 0-5
- FLOAT Return
ReadPressureRaw
- BYTE Resolution
Range 0-5
- ULONG Return
ReadTemperatureRaw
- BYTE Resolution
Range 0-5
- LONG Return
ReadPROM
- BYTE Address
Range 0-6
I2C Properties
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulate Comms
ReadPressureFloat
- BYTE Resolution
Range 0-5
- FLOAT Return
Reset
Resets the device
- BYTE Resolution
Range 0-5
- FLOAT Return
ReadPressureRaw
- BYTE Resolution
Range 0-5
- ULONG Return
ReadTemperatureRaw
- BYTE Resolution
Range 0-5
- LONG Return
ReadPROM
- BYTE Address
Range 0-6
I2C Properties
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulate Comms
ReadPressureFloat
- BYTE Resolution
Range 0-5
- FLOAT Return
Reset
Resets the device
- BYTE Resolution
Range 0-5
- FLOAT Return
ReadPressureRaw
- BYTE Resolution
Range 0-5
- ULONG Return
ReadTemperatureRaw
- BYTE Resolution
Range 0-5
- LONG Return
ReadPROM
- BYTE Address
Range 0-6
I2C Properties
Channel selection
SDA
SCL
Baud Select
Stop Delay
Simulate Comms
