| Author
Matrix Ltd.
| Version
1.3
| Category
Comms: USB
USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
Please click here to download the component source project: FC_Comp_Source_USBMIDI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBMIDI.fcfx
SendMIDI
| Sends a MIDI packet consisting of up to three bytes of information,
- BYTE
Status
| MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
- BYTE
Data1
| MIDI Data Byte - Used as a parameter specific to the specified command
- BYTE
Data2
SendPitchChange
| Sends out a pitch change command on the specified channel.
- BYTE
| Channel to send the pitch change to
- UINT
Pitch_Change
| New pitch value to use, Default 0x2000
SendNoteOff
| Sends a note off command using the channel, note and velocity specified.
- BYTE
- BYTE
Note
- BYTE
Velocity
SendControl
| Sends a control command using the channel, controller and value specified.
- BYTE
- BYTE
Controller
- BYTE
Value
SendNoteOn
| Sends a note on command using the channel, note and velocity specified.
- BYTE
- BYTE
Note
- BYTE
Velocity
ReceiveMIDI
| Waits for the time specified in the timeout parameter for an incoming MIDI message. Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
- BYTE
Timeout
- BYTE
SendPolyPressure
| Sends a note press with an associated polyphonic pressure value.
- BYTE
- BYTE
Note
- BYTE
Pressure
ReadData
| Reads a byte from the last received MIDI message
- BYTE
Idx
| Byte to read 0-3
- BYTE
SendPatch
- BYTE
- BYTE
Instrument
SendChannelPressure
- BYTE
- BYTE
Pressure
| Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
- BYTE
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
| USB Major Version Number
Minor Version
| USB Minor Version Number
Enumeration Timeout
| Specifies if the enumeration (Initialise function) can timeout if taking too long.
| Text displayed on the I/O flasher comms component.
Data Source
| Simulation data source used to allow the component to connect to specific MIDI hardware or the the data injector components.
MIDI Port
SendMIDI
- BYTE
Status
- BYTE
Data1
- BYTE
Data2
SendPitchChange
- BYTE
- UINT
Pitch_Change
SendNoteOff
- BYTE
- BYTE
Note
- BYTE
Velocity
SendControl
- BYTE
- BYTE
Controller
- BYTE
Value
SendNoteOn
- BYTE
- BYTE
Note
- BYTE
Velocity
ReceiveMIDI
- BYTE
Timeout
- BYTE
SendPolyPressure
- BYTE
- BYTE
Note
- BYTE
Pressure
ReadData
- BYTE
Idx
| Byte to read 0-3
- BYTE
SendPatch
- BYTE
- BYTE
Instrument
SendChannelPressure
- BYTE
- BYTE
Pressure
- BYTE
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
Minor Version
Enumeration Timeout
Data Source
MIDI Port
SendMIDI
- BYTE
Status
- BYTE
Data1
- BYTE
Data2
SendPitchChange
- BYTE
- UINT
Pitch_Change
SendNoteOff
- BYTE
- BYTE
Note
- BYTE
Velocity
SendControl
- BYTE
- BYTE
Controller
- BYTE
Value
SendNoteOn
- BYTE
- BYTE
Note
- BYTE
Velocity
ReceiveMIDI
- BYTE
Timeout
- BYTE
SendPolyPressure
- BYTE
- BYTE
Note
- BYTE
Pressure
ReadData
- BYTE
Idx
| Byte to read 0-3
- BYTE
SendPatch
- BYTE
- BYTE
Instrument
SendChannelPressure
- BYTE
- BYTE
Pressure
- BYTE
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
Minor Version
Enumeration Timeout
Data Source
MIDI Port
SendMIDI
- BYTE
Status
- BYTE
Data1
- BYTE
Data2
SendPitchChange
- BYTE
- UINT
Pitch_Change
SendNoteOff
- BYTE
- BYTE
Note
- BYTE
Velocity
SendControl
- BYTE
- BYTE
Controller
- BYTE
Value
SendNoteOn
- BYTE
- BYTE
Note
- BYTE
Velocity
ReceiveMIDI
- BYTE
Timeout
- BYTE
SendPolyPressure
- BYTE
- BYTE
Note
- BYTE
Pressure
ReadData
- BYTE
Idx
| Byte to read 0-3
- BYTE
SendPatch
- BYTE
- BYTE
Instrument
SendChannelPressure
- BYTE
- BYTE
Pressure
- BYTE
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
Minor Version
Enumeration Timeout
Data Source
MIDI Port
