| Author
Matrix Ltd.
| Version
2.1
| Category
Comms: Networking
WLAN (ESP-12S) component
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP12S.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP12S.fcfx
SendString
| Sends the given Text with no preappendment. Useful for sending preformatted command strings. Appends a CR to the end of the string if SendCR is greater than 0.
  - STRING
Text
  - BYTE
SendCR
DisconnectFromSSID
| Disconnects from the current SSID.  Returns 1 if the command was accepted and returned an "OK"
  - BYTE
ClientConnect
| Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
  - BYTE
Type
| 0 = TCP, 1 = UDP
  - STRING
IPAddress
| e.g. "192.168.1.20"
  - UINT
Port
| Remote port number to connect to, HTTP comms = Port 80
  - BYTE
ControlTCPServer
| Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
  - BYTE
Enable
| 0 = Stop Server, 1 = Start Server
  - UINT
Port
| Server port to listen for incoming TCP/IP data requests
  - BYTE
GetFirmwareVersion
| Collects the firmware version from the ESP8266 module and returns it as a string.
  - STRING
CheckForPageRequests
| To be called periodically. Returns non-zero if a request has been processed
  - BYTE
ClientSendRequest
| Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser.
  - STRING
Request
| e.g. "GET / HTTP/1.0\r\n\r\n"
ReadSSIDFromScan
| Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
  - BYTE
Index
| SSID Index
  - STRING
CreateAccessPoint
| Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
  - STRING
SSID
| Name of the wireless network to create
  - STRING
Password
| Password used to gain access to the network
  - BYTE
| 802.11 Channel Range 1-14
  - BYTE
Encryption
| 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
  - BYTE
SetOutValue
| Set the value of an outbound substitution string
  - BYTE
index
| Range 0-4
  - STRING
value
EndServerConnection
| Disconnects from the current active TCP/IP pipe.
  - BYTE
Send_Embedded_HTML_Page4
ReadSignalStrengthFromScan
| Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
  - BYTE
Index
| SSID Index
  - INT
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page1
ReadEncryptionModeFromScan
| Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
  - BYTE
Index
| SSID Index
  - BYTE
GetByteWithTimeout
| Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
  - BYTE
GetInValue
| Returns the string value of a Request parameter
  - BYTE
index
| Index of the request paramter, starting at zero Range 0-2
  - STRING
ConnectToSSID
| Attempts to connect to the given SSID and Key values.  Returns 1 if the SSID has been connected.
  - STRING
SSID
  - STRING
Key
  - BYTE
Timeout
| Number of seconds to wait for the connection, default 20
  - BYTE
ClientSendArray
| Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser.
  - BYTE
Data
  - UINT
NumBytes
GetRxArray
| Attempts to receive a number of bytes from the remote connection If nothing is available then waits up to 200 ms for data to become available. Returns the number of bytes received,.
  - BYTE
Data
| Byte array to store the incoming data
  - UINT
MaxBytes
| Maximum number of bytes to try and receive
  - UINT
ScanForSSID
| Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
  - BYTE
| Initialise the device with the property data. Returns 1 if "ready" message successfully received  Returns 0 if no reply from module
  - BYTE
CheckTCPServerIP
| Collects the local IP address of the active TCP server.
  - STRING
WIFI Properties
Receive Buffer Size
| Buffer used to store incoming data ready for processing. Default 128 Bytes.
Scan Buffer Size
| Buffer used to hold SSID names when performing a SSID network scan. Default 100 Bytes.
Reset Mode
| The initialise automatically resets the WIFI module before establishing communications. Software reset uses an AT command to preform the reset Hardware reset uses an extra I/O pin to toggle the signal to the reset pin on the module.
Command Termination
| Older versions of the firmware require \r to terminate a AT command string. Newer versions of the firmware have changed to use \r\n termination.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Reset
| WLAN module reset pin connection
Use Flow Control
| Flow Control (Handshake) enable or disable.     On: Two I/O pins are used to control the flow of data in and out of the device.     Off: Flow control is disabled.
HTML Source
Max Web Pages
| Maximum number of individual webpages we can serve up with the component.
Web Page Timeout
| Number of cycles to try and send / receive a webpage before timing out.
Line Delay
| Fixed delay in microseconds sent in between sending a HTML line when running as a web page server.
Name Page 1
| HTML name of webpage 1
HTML Page 1
| HTML content for webpage 1
Name Page 2
| HTML name of webpage 2
HTML Page 2
| HTML content for webpage 2
Name Page 3
| HTML name of webpage 3
HTML Page 3
| HTML content for webpage 3
Name Page 4
| HTML name of webpage 4
HTML Page 4
| HTML content for webpage 4
Substitutions
Outgoing
Count
| Maximum number of outbound string substitutions
Length 0
| Number of bytes to reserve for data string.
Incoming
Count
| Maximum number of inbound string substitutions
Length 0
| Text label used to help identify the component on the panel.
Simulation Method
| Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
| Decides if simulation TCP data is available via a console tab
SendString
  - STRING
Text
  - BYTE
SendCR
DisconnectFromSSID
  - BYTE
ClientConnect
  - BYTE
Type
| 0 = TCP, 1 = UDP
  - STRING
IPAddress
| e.g. "192.168.1.20"
  - UINT
Port
  - BYTE
ControlTCPServer
  - BYTE
Enable
  - UINT
Port
  - BYTE
GetFirmwareVersion
  - STRING
  - BYTE
ClientSendRequest
  - STRING
Request
ReadSSIDFromScan
  - BYTE
Index
| SSID Index
  - STRING
CreateAccessPoint
  - STRING
SSID
  - STRING
Password
  - BYTE
  - BYTE
Encryption
  - BYTE
SetOutValue
  - BYTE
index
| Range 0-4
  - STRING
value
EndServerConnection
  - BYTE
  - BYTE
Index
| SSID Index
  - INT
  - BYTE
Index
| SSID Index
  - BYTE
GetByteWithTimeout
  - BYTE
GetInValue
  - BYTE
index
  - STRING
ConnectToSSID
  - STRING
SSID
  - STRING
Key
  - BYTE
Timeout
  - BYTE
ClientSendArray
  - BYTE
Data
  - UINT
NumBytes
GetRxArray
  - BYTE
Data
  - UINT
MaxBytes
  - UINT
ScanForSSID
  - BYTE
  - BYTE
CheckTCPServerIP
  - STRING
WIFI Properties
Receive Buffer Size
Scan Buffer Size
Reset Mode
Command Termination
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Reset
Use Flow Control
HTML Source
Max Web Pages
Web Page Timeout
Line Delay
Name Page 1
HTML Page 1
Name Page 2
HTML Page 2
Name Page 3
HTML Page 3
Name Page 4
HTML Page 4
Substitutions
Outgoing
Count
Length 0
Incoming
Count
Length 0
Simulation Method
SendString
  - STRING
Text
  - BYTE
SendCR
DisconnectFromSSID
  - BYTE
ClientConnect
  - BYTE
Type
| 0 = TCP, 1 = UDP
  - STRING
IPAddress
| e.g. "192.168.1.20"
  - UINT
Port
  - BYTE
ControlTCPServer
  - BYTE
Enable
  - UINT
Port
  - BYTE
GetFirmwareVersion
  - STRING
  - BYTE
ClientSendRequest
  - STRING
Request
ReadSSIDFromScan
  - BYTE
Index
| SSID Index
  - STRING
CreateAccessPoint
  - STRING
SSID
  - STRING
Password
  - BYTE
  - BYTE
Encryption
  - BYTE
SetOutValue
  - BYTE
index
| Range 0-4
  - STRING
value
EndServerConnection
  - BYTE
  - BYTE
Index
| SSID Index
  - INT
  - BYTE
Index
| SSID Index
  - BYTE
GetByteWithTimeout
  - BYTE
GetInValue
  - BYTE
index
  - STRING
ConnectToSSID
  - STRING
SSID
  - STRING
Key
  - BYTE
Timeout
  - BYTE
ClientSendArray
  - BYTE
Data
  - UINT
NumBytes
GetRxArray
  - BYTE
Data
  - UINT
MaxBytes
  - UINT
ScanForSSID
  - BYTE
  - BYTE
CheckTCPServerIP
  - STRING
WIFI Properties
Receive Buffer Size
Scan Buffer Size
Reset Mode
Command Termination
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Reset
Use Flow Control
HTML Source
Max Web Pages
Web Page Timeout
Line Delay
Name Page 1
HTML Page 1
Name Page 2
HTML Page 2
Name Page 3
HTML Page 3
Name Page 4
HTML Page 4
Substitutions
Outgoing
Count
Length 0
Incoming
Count
Length 0
Simulation Method
SendString
  - STRING
Text
  - BYTE
SendCR
DisconnectFromSSID
  - BYTE
ClientConnect
  - BYTE
Type
| 0 = TCP, 1 = UDP
  - STRING
IPAddress
| e.g. "192.168.1.20"
  - UINT
Port
  - BYTE
ControlTCPServer
  - BYTE
Enable
  - UINT
Port
  - BYTE
GetFirmwareVersion
  - STRING
  - BYTE
ClientSendRequest
  - STRING
Request
ReadSSIDFromScan
  - BYTE
Index
| SSID Index
  - STRING
CreateAccessPoint
  - STRING
SSID
  - STRING
Password
  - BYTE
  - BYTE
Encryption
  - BYTE
SetOutValue
  - BYTE
index
| Range 0-4
  - STRING
value
EndServerConnection
  - BYTE
  - BYTE
Index
| SSID Index
  - INT
  - BYTE
Index
| SSID Index
  - BYTE
GetByteWithTimeout
  - BYTE
GetInValue
  - BYTE
index
  - STRING
ConnectToSSID
  - STRING
SSID
  - STRING
Key
  - BYTE
Timeout
  - BYTE
ClientSendArray
  - BYTE
Data
  - UINT
NumBytes
GetRxArray
  - BYTE
Data
  - UINT
MaxBytes
  - UINT
ScanForSSID
  - BYTE
  - BYTE
CheckTCPServerIP
  - STRING
WIFI Properties
Receive Buffer Size
Scan Buffer Size
Reset Mode
Command Termination
Baud Options
TX
TX Remap Pin
RX
RX Remap Pin
Reset
Use Flow Control
HTML Source
Max Web Pages
Web Page Timeout
Line Delay
Name Page 1
HTML Page 1
Name Page 2
HTML Page 2
Name Page 3
HTML Page 3
Name Page 4
HTML Page 4
Substitutions
Outgoing
Count
Length 0
Incoming
Count
Length 0
Simulation Method
