| Author
Matrix Ltd
| Version
1.1
| Category
Switch (Push, PCB) component
Simple tactile PCB switch for PCB mounting. Approx. 12 * 12mm. Color and operation can be set from properties.
Please click here to download the component source project: FC_Comp_Source_sw_push_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
Connection
| The chip pin to which the switch connects.
Polarity
| Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = On, Released = Off 'Active Low' -> Pressed = Off, Released = On
Debounce (ms)
| Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Operation
| Latching = Mouse click to turn on, click again to trun off. Momentary = Click to turn on, release to turn off.
Color
| Color of the key cap
Connection
Polarity
Debounce (ms)
Operation
Color
Connection
Polarity
Debounce (ms)
Operation
Color
Connection
Polarity
Debounce (ms)
Operation
Color
