| Author
Matrix Ltd
| Version
1.1
| Category
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang. Pins for PCB mounting.
Please click here to download the component source project: FC_Comp_Source_sw_toggle_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_toggle_pcb.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
Connection
| Chip pin to which this switch is connected.
Polarity
| Sets whether the pin should go high or low when the switch is activated.
Debounce (ms)
| Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state with the component macros. Chip pin is NOT debounced.
Operation
| Latching - click the switch to turn it on, click again to turn it off. Momentary - click the switch to turn it on, release the mouse to turn it off.
Connection
Polarity
Debounce (ms)
Operation
Connection
Polarity
Debounce (ms)
Operation
Connection
Polarity
Debounce (ms)
Operation
