| Author
MatrixTSL
| Version
2.0
| Category
Comms: System
DMX-512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here to download the component source project: FC_Comp_Source_DMX-512_Master.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DMX-512_Master.fcfx
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet.
DMX Master Example1
For DMX 512 slave example see: DMX Slave
SetDataChannel
| Sets the data byte in a data channel
- UINT
- BYTE
DataValue
SendDataChain
| Transmits the BREAK, MAB and StartCode followed by the contents of the data channels.
- BYTE
StartCode
| Configures the UART serial interface.
Serial Properties
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
DMX Properties
Data Channels
| Number of data bytes used by the DMX chain, Max 512 bytes per transmission. 24 Bytes minimum to match minimum 1204us timing requirements, not all channels need to be used.
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port Injector - Routes the communication data via a data injector component on the Panel.
