Component: Switch (Push, Dashboard) ()
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
Switch (Push, Dashboard) component
Simple momentary push-button using the Matrix dashboard theme.
Please click here to download the component source project: FC_Comp_Source_Dashboard_Button.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dashboard_Button.fcfx
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
Connection
Chip pin to which the button is connected.
Polarity
Whether the pin is taken high or low by pressing the button.
Debounce (ms)
Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state using the component macros. Chip pins are NOT debounced!
Text
Text for the label displayed below the button.
Font
Font to use for the text label beneath the buttion.
Label Color
Color for the test of the label shown beneath the button.
Bezel Color
Color for the bezel surrounding the button.
Button Color
Color of the moving part of the button.
Operation
Latching = Mouse click to turn on, click again to turn off. Momentary = Click to turn on, release to turn off.
