Component: Electrical Machines (AllCode)
Version | 2.0 |
Category | AllCode |
Electrical Machines component
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
Please click here to download the component source project: FC_Comp_Source_EM_Functions.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_EM_Functions.fcsx
GetLogDataReady |
Checks to see if the logging is complete and ready to read. | |
Return |
GetRPM |
Reads the speed in RPM | |
Return |
GetWeight |
Reads the voltage of a single channel | |
Scale |
Range: 0-1 - 0=Weight, 1=Torque | |
Return |
SetControlKP |
Value |
Return |
SetControlSetpoint |
Value |
Return |
GetAPIVersion |
Reads the API firmware version | |
Return |
GetLogData |
Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK | |
Buffer |
Buffer to store the incoming log data | |
Return |
GetSafetySwitch |
Reads the safety switch | |
Return |
SetControlKI |
Value |
Return |
ZeroLoadCell |
Return |
SetControlMaxDrivePercentage |
Value |
Range 0.0-1.0 | |
Return |
SetMotorType |
MotorType |
0=DC, 1=1 Phase, 2=3 Phase | |
Return |
SetLoadCellCalibration |
Value |
Return |
GetVoltage |
Channel |
Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT | |
Return |
GetControlFeedback |
Return |
SetControlKD |
Value |
Return |
SetCapacitorBank |
Cap |
Return |
GetCommsOK |
Checks if comms are ok and stable | |
Return |
GetLogStartAngle |
Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data. | |
Return |
SetVoltage |
Sets the DC Voltage from 0 to 24V | |
Voltage |
Index |
Return |
Get3PhaseMode |
Checks to see if the brushless mode is enabled | |
Return |
GetAbsPosition |
Reads the absolute position of the encoder | |
Return |
SetFan |
|Sets the speed of the FAN from 0 (MIN) to 3000 (MAX) | |
Speed |
Return |
SetMotorDirection |
MotorDirection |
0=FW, 1=BW | |
Return |
GetMotorDirection |
Reads the motor direction | |
Return |
SetThreePhaseDriveMode |
Mode |
0=Simple, 1=Accurate | |
Return |
GetCurrent |
Reads the current of a single channel | |
Channel |
Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver | |
Return |
SetFrequency |
Frequency |
Frequency of sine wave in Hz | |
Return |
SetDynoLoad |
Load |
Return |
GetControlOutputs |
Data |
Return |
SetActive |
Active |
0=Off, 1=On | |
Return |
SetDriveMode |
Mode |
0=PWM, 1=On/Off/Float | |
Return |
SetTCPProps |
Sets the TCP IP address and Port | |
IP0 |
IP1 |
IP2 |
IP3 |
Port |
Return |
SetAbsPosition |
Resets the absolute motor position to 0 | |
Return |
Initialise |
Returns 1 if the connection is ok and communications have been established | |
MotorType |
0=DC, 1=1Phase, 2=3Phase, 3=AngleControl | |
Return |
