Component: EtherCAT Slave (EasyCAT) (Comms: IoT/Cloud)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Category Comms: IoT/Cloud
EtherCAT Slave (EasyCAT) component
Provides support for the EtherCAT Slave industrial protocol using an EasyCAT Arduino shield. The shield can be driven from a Flowcode compatible Arduino type board or can be driven using an Arduino using the SCADA Slave firmware to drive EtherCAT from the Flowcode simulation runtime. Compatible with the EasyCAT Easy Configurator tool.
Please click here to download the component source project: FC_Comp_Source_EasyCat.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EasyCat.fcfx
Fc9-comp-macro.png SetInt
Write a 16-bit value to the In receive buffer
Fc9-u8-icon.png - BYTE Index
Data Index
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png MainTask
Must be called as part of the application main program loop.
Fc9-comp-macro.png SetLong
Write a 32-bit value to the In receive buffer
Data Index
Fc9-u32-icon.png - ULONG Data
Fc9-comp-macro.png GetFloat
Read a 32-bit floating point value from the Out receive buffer
Data Index
Fc9-comp-macro.png GetLong
Read a 32-bit value from the Out receive buffer
Data Index
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png GetInt
Read a 16-bit value from the Out receive buffer
Data Index
Fc9-comp-macro.png SetByte
Write an 8-bit value to the In receive buffer
Data Index
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png GetByte
Read a 8-bit value from the Out receive buffer
Data Index
Fc9-comp-macro.png SetFloat
Write a 32-bit floating point value to the In receive buffer
Data Index
Fc9-f32-icon.png - FLOAT Data
Fc9-comp-macro.png Initialise
Starts up the SPI connection to the EasyCAT board and configures the board. Returns 1 for a sucessful initialise.
Fc9-type-16-icon.png Synchronisation Mode
ASYNC = free running i.e. no synchronization between master and slave (default) DC_SYNC = interrupt is generated from the distributed clock unit SM_SYNC = interrupt is generated from the syncronisation manager
Fc9-type-13-icon.png Header File
Used to load a header file from Easy CAT Configurator tool to describe the units inputs and outputs
Fc9-conn-icon.png Data Rx
Fc9-type-21-icon.png Total Byte Num Out
Total number of bytes to come out from the EtherCAT master
Fc9-conn-icon.png Data Tx
Fc9-type-21-icon.png Total Byte Num In
Total bytes to come in from the EtherCAT master
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Simulation Comms
